warm engine won't start...HELP!
Old Oct 15, 2001 | 01:30 AM
thewalk's Avatar
thewalk
Default warm engine won't start...HELP!
I have a stock '87 LT-1 with 147k mis. on it that runs GREAT. If i haven't run it in a day or two, it can be started EASILY by reaching in the window and blipping the key. However, if it has been run AT ALL that day, I gotta hold the gas to the floor to get it to start and then grey smoke pours out of the mufflers for a couple of seconds. I then have to keep it running with the gas for a minute until it "catches up with itself". No codes are present, and I have recently replaced the MAF and TPS with no change (different problems).
HELP!
Old Oct 15, 2001 | 01:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: warm engine won't start...HELP! (thewalk)
Try holding the accelerator down full for 30 sec before starting it warm. If it starts right up, likely a leaking fuel injector.
Old Oct 15, 2001 | 01:47 AM
thewalk's Avatar
thewalk
Default Re: warm engine won't start...HELP! (65Z01)
thank you very much; i will try that!
Old Oct 15, 2001 | 01:48 AM
thewalk's Avatar
thewalk
do i continue to hold the gas down as i turn it over, or release just before turning the key?
Old Oct 15, 2001 | 02:49 AM
moffitt's Avatar
moffitt
You might also check the coolant sensor, I have seen them fail. What they do is send a signal to the ECM that the engine is always cold, this makes the ECM send fuel for a cold engine on a hot start. It makes them too rich to run.
Old Oct 15, 2001 | 01:09 PM
jfb's Avatar
jfb
Leaky fuel injectors usually make it hard and long crank to start. When warm and it won't start easily, unplug the start injector and try a start. If it starts ok, then you have a defective coolant sensor (front of engine).
Old Oct 15, 2001 | 01:46 PM
GlockLT4's Avatar
GlockLT4
Default Re: warm engine won't start...HELP! (moffitt)
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: Check this! :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Old Oct 15, 2001 | 10:27 PM
93vetteguy's Avatar
93vetteguy
HELP!
Leaky fuel injector...but I really like to know did the LT-1 come in the '87 or the L-98...just asking.... :smash:
Old Oct 15, 2001 | 10:45 PM
thewalk's Avatar
thewalk
Default Re: warm engine won't start...HELP! (93vetteguy)
thanks alot!
i don't know where the start injector is, but i will try and find out, cause that is what i was thinking- choking when hot.
i don't mean to sound ignorant, but a guy who's supposed to be an expert told me i have an LT-1. i guess it hasn't mattered much to me, because i don't have any money to make it faster.
Old Oct 15, 2001 | 10:51 PM
93vetteguy's Avatar
93vetteguy
I am no expert but I think the LT-1, LT-4 are in the 92-96....and the LT-4 are 6 speed.. LT-5 is the zr-1... just a guess... I am a newbie.... :cheers:
Old Oct 15, 2001 | 10:57 PM
Lv2Driv's Avatar
Lv2Driv
L-98 others came after 92 i believe.
Old Oct 16, 2001 | 12:49 PM
jfb's Avatar
jfb
The cold start injector is on the left side of the intake about half way down the manifold.
Old Oct 16, 2001 | 12:57 PM
scorp508's Avatar
scorp508
Default Re: warm engine won't start...HELP! (jfb)
L83 = 1984
L98 = 1985-1991
LT1 = 1992-1995
LT1 = 1996 w/Automatic Transmission
LT4 = 1996 w/Manual Transmission
LT5 = 1990-1995 w/ZR1
Old Oct 16, 2001 | 02:13 PM
88L98's Avatar
88L98
Default Re: warm engine won't start...HELP! (scorp508)
im with everyone else, sounds like you have leaky injectors or injectors that are breaking down and the resistance inside them is getting low when they are hot.
Old Oct 21, 2001 | 02:45 AM
thewalk's Avatar
thewalk
Default Re: warm engine won't start...HELP! (88L98)
thanks guys!
i checked my vin decoding and i (of course) have an L-98 motor. where is the starter injector?
my manual is a pain to decipher...
marc
To warm engine won't start...HELP!
