Wheel size question - mixed sizes on a C4
Old Apr 4, 2007 | 10:02 PM
Eakster's Avatar
Eakster
Default Wheel size question - mixed sizes on a C4
Does anyone ride with 18"s on the rear and 17"s on the front?
Was this the ZR1 spec with its mag wheels?
Does it work for C4?
and lastly will having 18/35 tires mess up the speedo - rather than 17/40 (does the speedo run off the transmission?)
I have a good reason for asking
-Eaks
Old Apr 4, 2007 | 11:52 PM
Curveit's Avatar
Curveit
I've had this set up for years on my '86... 9.5x17 and 10.5x18 with 275/40/17 fronts and 295/35/18 rears. If the heigth of two tires is the same, or very close, they will read the same with your speedo. Won't alter your "over-all" gear ratio either. ZR1 had 9.5x17 and 11x17.
Old Apr 5, 2007 | 12:01 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
And that's the exact same wheel and tire size combo I'm running.
Old Apr 5, 2007 | 01:29 AM
FOXX's Avatar
FOXX
Total tire diameter
Front 275/40/17 = 25.66"
Rear 295/35/18 = 26.1299"
Old Apr 5, 2007 | 08:13 AM
TA's Avatar
TA
http://www.miata.net/garage/tirecalcold.html
Old Apr 5, 2007 | 08:58 PM
Cruising91's Avatar
Cruising91
Lets see some pics of some of the wheel combinations.
Old Apr 5, 2007 | 10:49 PM
Eakster's Avatar
Eakster
Thanks for the info, and the tire size thingamy
I haven't seen this type of combo except on C5 and C6's and the other day I found some really nice GM mag wheels - they look like the classic A-line for Corvette - but were 17 front and 18 rear which I thought was unusual. I know widths changed a lot on the C4 over the years but diameter..?
Trying to decide between buying these or sorting my car audio.
What's more important - what my car looks like or my experience inside it...hmmm
Old Apr 6, 2007 | 05:07 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
More important to you?
Or more important to me?
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 6, 2007 | 06:38 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Do a search and you'll find pics....
To Wheel size question - mixed sizes on a C4
