A/C question
Old Apr 5, 2007 | 12:39 PM
Great White North's Avatar
Great White North
Default A/C question
Can you tell me the difference between a 1988 compressor/clutch and a 1990to 1996?
Old Apr 5, 2007 | 01:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The compressor was "upgraded" from '87 to '88; I thought they kept the same compressor at least through '91...
Old Apr 5, 2007 | 01:16 PM
SunCr's Avatar
SunCr
Essentially they're all the same - Compressor is the Nippondenso Model 10PA20C. The LT motors (92 up) have a different manifold (it faces forward) and probably uses sealing washers for the main hose instead of o-rings. I know there are different clutch #'s but they all use the same diameter coils and 2 pin connectors. My guess is that some may have the diode in the coil, the others are in the connectors. The diode keeps it from frying parts when the clutch disengages.
Old Apr 5, 2007 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
2-8 years
Old Apr 8, 2007 | 07:40 PM
Great White North
Originally Posted by AGENT 86
2-8 years
Hi Dan!!!Just spent the weekend sledding!!When the sledding is done I need a new ac compressor and I see the 1990 is cheaper and I was just curious if there was a physical difference or just the seals for different freon.When I change it out we will be up for a little golf and beer!!!
Old Apr 8, 2007 | 11:36 PM
AGENT 86's Avatar
AGENT 86
Just finished 18 holes in 2 1/2 hours. I think with nitrous, I can get it done in less than 2.
To A/C question
