Antenna Problem
Old Apr 5, 2007 | 10:13 PM
tonyd9's Avatar
tonyd9
6th Gear
Default Antenna Problem
1994 vert power antenna won't go up or down but motor runs. What is best fix.
Old Apr 6, 2007 | 12:01 AM
DougSilver's Avatar
DougSilver
Sounds like maybe just replacing the mast will work. You can get these off ebay for under $15.
Doug
Old Apr 6, 2007 | 08:15 AM
tonyd9's Avatar
tonyd9
6th Gear
Thanks Doug. I saw them on Ebay but thought it would be a huge project to replace.
Tony
Old Apr 6, 2007 | 08:23 AM
sraft's Avatar
sraft
Tony,
replacing the mast is easy, but be aware that if the ribbon cable has broken into two pieces inside the housing, sometimes the broken piece gets left behind when you pull out the mast. Then you have to remove the entire antenna to to try and get it out.
Old Apr 6, 2007 | 08:42 PM
tonyd9's Avatar
tonyd9
6th Gear
Thanks for the reply I'am going to place an order on Ebay for the mast. i will let you know how it works out. Tony
Old Apr 6, 2007 | 11:51 PM
Sam Lam's Avatar
Sam Lam
Tony: I believe you can buy a GM mast for about $20 or less from Chris at Superior Chevy. I would not go to the trouble of removing the motor assy (like scraft suggested) with a non GM part. I have not had good service on non-GM parts like the mast assy.
Sam Lam's Avatar
Sam Lam
Duplicated post and do not know how I did this
Old Apr 8, 2007 | 01:55 PM
tonyd9's Avatar
tonyd9
6th Gear
Thanks, my wife ordered it thru a Chevy dealer supposed to be oem
Tony
Old Apr 8, 2007 | 06:42 PM
JAKE's Avatar
JAKE
96 LT1.
Well, mine has developed a quirk too. It'll go up but won't go down. I believe the cold, Indiana weather has taken its toll, so I'm looking at replacing the entire unit.
JAKE
Old Apr 8, 2007 | 07:31 PM
Strick's Avatar
Strick
I had this problem a few years ago. I took out the entire motor assembly, easy to do, and found that my ribbon was broken. At that time, no one on the forum knew how to get the old ribbon still in the motor out. So I bought a new assembly. I followed Helms Service Manual instructions most of the way. I took off the rear wheel, removed the innner wheel well liner, and took out the outer rear light assembly so it was easy to get at. Time consuming, but not hard to do.
To Antenna Problem
