To answer your actual question, without going into the advantages of carb vs EFI, yes the computer will run everything else.
You need a vacuum advance distributor
A return-style regulator
Carb and intake
Brackets for the throttle cable (and trans cable if it applies to you)
After that the ECM doesn't really do anything. The dash will work fine because the signals go to the dash first, then the ECM. You will lose the MPG display, but all the important parts will work fine. You can do a search on the forum for MANY threads covering the advantages/disadvantages of carbs vs EFI, as well as threads containing part numbers of brackets, pictures, and detailed explanations.
huge step backwards,lol,thats why the fastest cars at the track run carbs,but dont do it,be very careful,you might go faster!
Get yourself a dictionary and look up the word "technology". Do you see a level of performance associated with the definition? Then, go count the carbs on John Force's funny car. Next, go check your post count and pat yourself on the back for the worthless posts you made to this thread. Finally, go to the grammar barrel and see if you can fish out a capital letter or two, some periods and apostrophes, and maybe even some sentence structure.
RACE ON!!!
being that you have a 13 sec fuel injected car i think i wont take your advice! who cares about technology on a c4,im sure people would agree with me that if we wanted a technologically advance car we would not have gotten 23-11 year old cars!
race on!!! in the 13 sec club!!!
RACE ON!!!
man is my back throbbing!!! oh and i hope they dont ban me from this site for bad grammer.
Carbs have their place... on a 1959 Buick comes to mind. Carbs are simple, but they are crude analog devices. Their linearity is only limited to their built in range. Hence, 4bbl carbs... but even then, they are sometimes tricky to get right. EFI has the linearity and tunabilty that only a carb can dream of. Given the right intake, the L98 with EFI will beat the hell out of a carb.
All Show - a 13 second, nearly stock xfire is pretty impressive. What kinda ETs are you producing?
I don't race, so I can't answer that question. But I will tell you this - if I was to build a race car, or older hot rod, I will install some form of EFI. Holley, FAST, Edelbrock... take your pick.
if you know how to properly tune your own carb i would go carbed, last time i tracked it with drag radials i ran 12.4 at 116, the reason i went carb is cuz it sure beats the hell out of tpi,and to answer the question of a fi l98 vs a carbed l98 i deff think it depends on the the fi setup, if it was a tpi vs a carb i deff dont think the tpi would win especially with the car dying a 4800 rpm.
and you just said what I said. TPI does suck... but once the intake is replaced, another 1000 rpm is found and drivability isn't lost.
By the time you buy a carb, retro fit it, get the intake and mess with all that crap, a Super Ram could be installed, emissions maintained and performance equalled, if not exceeded.
$$ for $$, the super ram is not a bad way to go, compared with the angst of screwing up the entire car and installing a carb.
TPI, as an electronics system is capable. However, the intake is a mess. The other downside is that the stock ECU is hard to tune these days - too many people have forgotten how to do it.
Gentlemen: (used loosely)
Tpi is 25 year old technology that was the beginning of the musclecar comeback. It's not perfect, is RPM limited as stock, but it supplies tremendous driveability, reliability, and gas mileage when applied correctly. Totally tuneable and upgradeable for large power.
Carbs may provide as much horsepower when tuned correctly, but suffers driveability and less fuel mileage, and is a century old.
Stock carburetors are also horsepower and torque limiting.
Carburetion is not dead, it just isn't the latest thing anymore. It's still being improved as science allows. So is TPI.
Each is a trade off, and both have their place, and both have been replaced as the choice for manufacturers to install on the assembly lines. That is because for fuel and emissions, they have gone past accelerator pumps and batch fire injector programs.
Face it, it's almost the same type of argument as the ford/chevy argument, and each person has to decide what is best or fancies is the best for them.
Grow up, and co-exist in this fascinating techno world we live in, and stop bickering over the really small stuff.
okay here is the deal why im probably going carb. i just got a monster of a motor ,afr heads lunati crank trw pistons ect.,and it has a bolt on after market fuel injection system from a company called f.a.s.t. it has a brand new computer that piggy backs into the stock computer with a 450hp chjp,adjustable modes in the car so you can change settings on the fly.so new omp,new wiring harness,&instuction manual even giving mode settings. problem, i cant find anyone in the la area that will tune it for any less than my first born! also what i ment will the ecm still work my 700 r tranny
You will need to buy an O/D kit. Not expensive, not hard to install.
I have done this conversion(to carb). Let me know if I can help.
it would be greatly ap.if i could get as much info as possable.i really want to sell the aftermarket f.i. its new and very heavy duty but i think i wanna put a carb on it.
After 3 months of crappy performance and one code pulling fiasco after another....no starts, hard starts, won't idle, drives terrible, dies in the middle of an intersection, etc., etc.....
I made the decision to make the conversion. It was the right choice for me given the condition of the original TPI...coupled with my (admittedly) unwillingness to spend the time to learn the ins and outs of the system. I am very satisified with the result....start up, driveability, gas mileage, and HP/TQ output. However, I have significant mods beyond just the TPI to carb conversion.
There are a number of us here that have made the conversion and are happy to help.
RACE ON!!!
Although I have come to appreciate the level of intelligence you bring to the table....I just don't understand why you are otherwise such an unhappy person.
