Engine interference with garage door opener!!!
Old Oct 15, 2001 | 07:35 PM
doc18015's Avatar
doc18015
Default Engine interference with garage door opener!!!
With the engine running in my 92 LT1, the remote control for the garage door will not operate. As soon as the engine is stopped, the door opener works fine. What is the fix? Thanks for your help....i am new to the site...it's GREAT! :yesnod:
Old Oct 15, 2001 | 07:53 PM
dtorc4's Avatar
dtorc4
Default Re: Engine interference with garage door opener!!! (doc18015)
Welcome to the Corvette Family!!!! :cheers: :cheers: :cheers:
Unfortuanately, I have NO idea wtf is going on :eek: I'm sure someone in here does. Good luck!
Old Oct 16, 2001 | 12:15 PM
SunCr's Avatar
SunCr
Living fairly close to a military airfield, I've heard of some low flying F18's opening up garage doors, but nothing about a motor blocking the signal. If you're opener has dip switches, try another setting. Engines do create electrical noise; so I'm guessing that your alternator or ignition is cancelling the frequency of yours.
Old Oct 16, 2001 | 12:43 PM
jfb's Avatar
jfb
The pulses from the spark plug wires causes interference to the garage door opener receiver. You might call the opener manufacturer. They might have a cure.
Old Oct 16, 2001 | 05:03 PM
GlockLT4's Avatar
GlockLT4
Default Re: Engine interference with garage door opener!!! (jfb)
:yesnod: :yesnod: Lots of things cause interference around our houses... you should see what happens when someone uses a blow drier in our place ... (we've got 7 computers) ... :eek: :eek:
Old Oct 16, 2001 | 06:08 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
The electrical noise from the spark plugs, injectors, alternator or even the keyless entry could make some stuff go crazy. Someone recently had an article talking about how the lower level spectrum for radio freqs are getting crowded because of all the fancy gadgets that we have. Good luck in finding the cause and welcome to the forum.
:seeya
Old Oct 16, 2001 | 07:05 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Engine interference with garage door opener!!! (96GrandSport)
Do you have the OEM type ignition wires or did you change them to an aftermarket brand such as Taylor? If so, you may want to try using the OEM type wires. At a dyno session, one of the cars with aftermarket wires created problems for the dyno system.
Old Oct 16, 2001 | 08:58 PM
cshuman's Avatar
cshuman
I agree with the idea that the electrical noise from the engine is causing the problem. Try setting in front of the garage door in the car and change the rpm of the engine while trying the opener to see if that has an effect. If it does try changing the dip switch settings as mentioned before.
Good Luck!
Old Oct 17, 2001 | 03:55 AM
wake's Avatar
wake
My old 88 IROC had an interference issue... When the car was running, none of my co-workers parked on either side of me could disarm their alarm systems...
I think it was something to do with the alternator/electrical system...
It was a weird thing...
Old Oct 17, 2001 | 10:26 AM
GRX's Avatar
GRX
Welcome to the forum! ....and, try replacing the battery in the opener. :flag
[Modified by GRX, 6:26 AM 10/17/2001]
Old Oct 17, 2001 | 10:44 AM
Tom Piper's Avatar
Tom Piper
My '92 Corvette does not interfere with my garage door opener, but my lawn tractor does.
I have to get away from, or turn off, the lawn tractor before raising the garage door.
Tom Piper
To Engine interference with garage door opener!!!
