92 code 34 root problem?
Old Apr 9, 2007 | 09:01 PM
BGH's Avatar
BGH
Default 92 code 34 root problem?
I just started getting a code 34 only on cold
start. My question is, could a sticking IAC
valve cause the MAP sensor to read incorrectly.
I have claned the throttle body once 2 mos ago
but did not pull off the throttle body, just sprayed
cleaner and wiped off the throttle area.
I am getting hesitation on full throttle also.
