What size tire?
Apr 9, 2007 | 11:22 PM
What size tire?
I bought some 15x3.5 wheels and was wondering what tires to go with.
Thanks,
Eric
Apr 10, 2007 | 12:06 AM
i will take a stab at it and say the skinniest 15" you can find.something like a 195/75/15 or even smaller than that.if they still make a 165sr15 or similar i would go that route.post in the drag section and i'm sure you will get a better response.
Apr 11, 2007 | 06:27 PM
Apr 11, 2007 | 06:59 PM
From: One day you're a Comet...the next day you're dust... Arkansas
A 165/70/15 should work well on a 3.5" wheel if you can find them.
Apr 12, 2007 | 11:04 AM
Sounds like "front runners" used by many roadsters, funnys and other light weight front engine dedicated drag race cars that need a full size (diameter) front tire, like 24+ inches in diameter. You can find these 3-1/2" wide wheel recommendations listed in any of the major drag race tire manufacturers.
Apr 12, 2007 | 04:54 PM
From: SCMR Rat Pack'r Charter Member..Great Bend KS
http://store.summitracing.com/egnsea...115+4294854911
..probably took me less time to find that than it did for you to post the question........
Larry
code5coupe
__________
I ain't easily impressed....
Apr 13, 2007 | 11:43 AM
Quote:
Originally Posted by
rocco16
I should have said what "cheap" tire will fit theses wheels, I already new about the good one's.
Thanks,
Eric
Apr 22, 2007 | 10:57 AM
I bought a set of Kuhmo 165/80/15 tires for around $ 35 ea.
Apr 22, 2007 | 11:38 AM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Simmons-Racing
Yep, the spec size for an early VW beetle. Back when we used them they were called a 5.60/15, the econo front drag tire.
