Does anyone know what the difference is here?
I know it doesn't show RPM but it does give you a good idea. If I would've left the TC unlocked on the bigger HP pull the low end TQ would've been quite a bit higher.
So what is the difference?
I hope those runs were free, cause that's about all they are worth.
Larry
code5coupe
__________
I ain't easily impressed....
Is the low HP run in 2nd gear with the converter unlocked?
Is the intake coupler collapsing or was the cat plugged and blew itself out between the runs?
Banana in the tailpipe?
Did you drive through deep snow on the way to the dyno?
Tires smokin' on the rollers?
Tell us more.
