90 Convertable A/C fixed & Upgrade Exhaust
Old Apr 12, 2007 | 06:57 PM
jghmczo6's Avatar
jghmczo6
Default 90 Convertable A/C fixed & Upgrade Exhaust
Thanks to members of this forum for guidance. Previously Climate Control continuously displayed 50* outside temp after reviewing other posts I began searching for codes. Found code 03 ambient sensor, shut off the A/C, pulled fuses #1 and #17, disconnected the outside temp sensor, disconnected the battery, then waited ten minutes. Reconnected the outside sensor, replaced the fuses, reconnected the battery, started the car and outside temp is reading correctly plus the heat / A/C works fine.
New Hooker long tube headers, and Corsica true duel exhaust, and it sound great!
Thanks again for your help
