Need a Replacement Distributor Plastic Connector
Old Apr 14, 2007 | 12:25 AM
Sam Lam's Avatar
Sam Lam
Default Need a Replacement Distributor Plastic Connector
I recently removed the dist cap from my 89. While removing the connecting wires, the white BAT plug latch broke off. See photo of the problem:
Anyone know where I can get a replacement white plastic connector? Thanks in advance.
Old Apr 14, 2007 | 01:12 AM
Siveck's Avatar
Siveck
Maybe one could be found in the "Help" section at the auto parts store? It should be a common GM part. I know that you can get one from PerformanceDistributors dot com.
Old Apr 14, 2007 | 01:31 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default connector
Car Quest always has a variety of them in stock. Check with Summit Racing, they sell HEI distributors, and have to sell the connectors for them.
Also check with MSD, they have to have them, and Painless Wire. THey make the harnesses for retrofit.
Old Apr 14, 2007 | 10:45 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Got mine at Summitt, but saw the same thing at NAPA
Old Apr 14, 2007 | 11:20 AM
Sam Lam's Avatar
Sam Lam
Thanks guys for the input. I found them online at Summit (thanks to coupeguy2001) and I have a NAPA store very close to me (thanks to vinnie). Problem will be solved toay
Old Apr 14, 2007 | 12:31 PM
MrRenoman's Avatar
MrRenoman
Mine was broke for years. It's amazing how well it stayed in there. Guess I should have fixed it before I sold the car. It'll be peace of mind knowing it's fixed and will prevent any problems.
Art
Old Apr 24, 2007 | 11:35 PM
Sam Lam's Avatar
Sam Lam
Got 'er done!
I went to quantity 2 friendly NAPA stores and asked for a GM HEI battery plastic connector. Both places said they could not help me. My son used to be a NAPA salesman and was certain that NAPA carries this part ........but Carquest did not have the part.
I then ordered a Summit part and it only cost $5.49 for a pigtail of red wire (8" long) with a terminal and the needed white plastic connector. Shipping was free, but the packing and handling was only $10.00! Bet you can estimate this bill!
The pigtail arrived and had a black wire....and I wanted Red! Got to looking at the pigtail assy and noticed the plastic connector could easily be removed form the terimnal and wire. Using a paper clip (wire diameter was .046 inches), I was able to remove the new connector form the Summit part and then put the new plastic connector on my old wire. I took me longer to open the hood than to replace the white plastic part
Hope this helps the next person with this problem
Old Apr 25, 2007 | 12:16 AM
RRT vette's Avatar
RRT vette
Thanks for the follow up Sam.
Old Apr 25, 2007 | 12:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm sure Napa has it but their workers are too stupid to realize it.
Unlike other parts stores, Napa trains their employees to not have dumb blank looks on their face when they have no idea what you're talking about.
To Need a Replacement Distributor Plastic Connector
