Tried a search, no luck
Old Apr 14, 2007 | 09:40 AM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
Default Tried a search, no luck
I noticed last night that when I am moving very slow, less than 10MPH, I can hear an odd sound coming from the front of the car, mostly the drivers side. The sound is a clanking, rattling, grinding kind of sound. It stops when brakes applied. Heading to a shop in a couple minutes. Any info here would be appreciated. thanks.
Old Apr 14, 2007 | 09:56 AM
LannyL81's Avatar
LannyL81
Could be your brake pads have lost one of the anti-rattle clips or could just be the pads dragging on the rotor a bit.
Hope its not more than that.
Good luck
Old Apr 14, 2007 | 10:12 AM
danziger's Avatar
danziger
I second the anti-rattle clips. One of mine broke and I have the exact same noise...
Old Apr 14, 2007 | 02:39 PM
carlton_fritz
Good luck
The sound was gone this morning when I drove the car. Last night it seemed to go with the rotation of the wheel like a rock in the tread would. Nothing seems to be wrong with handling, braking or anything. Just had that noise.
Old Apr 17, 2007 | 11:12 AM
LannyL81's Avatar
LannyL81
My '96 would make a noise at times that I could only hear when very slowly moving. I found that it was the front wheel bearing by having someone else drive the car while I was walking next to it. This way I was able to determine which wheel it was.
After lifting the front wheels, I found that the right front wheel bearing had movement sideways that the left front did not. Taking it out and comparing to a new one really showed the problem.
Front wheel bearings are very easy to replace. The rears...not so easy due to the half shafts.
Something you might want to check out.
Good luck with it.
To Tried a search, no luck
