Hesitation at WOT
Old Oct 16, 2001 | 08:34 PM
Coot's Avatar
Coot
Default Hesitation at WOT
I rarely do this, but I was feeling froggy today; from a dead stop, I matted the accelerator...car was strong for an instant, then a BAD hesitation, then OK again. A friend suggests running a can of Chevron injector cleaner though it. Car (93 C4 A4 by the way) runs strong in passing gear, no hesitation...any thoughts on this???
Old Oct 16, 2001 | 08:40 PM
White91's Avatar
White91
Default Re: Hesitation at WOT (Coot)
I would check your fuel pressure. I think that you either have a plugged fuel filter or a weak fuel pump. Since it's a '93 you can run a code check yourself so that you can rule out any electrical/sensor problems. :flag
Old Oct 17, 2001 | 01:16 PM
Coot's Avatar
Coot
Default Re: Hesitation at WOT (White91)
Thanks, White91...I'll check er out...
To Hesitation at WOT
