I changed sparkplugs today and ran into a problem. #2 plug appears to be held by some type of cream colored putty. The hole is filled all around the body of the plug. I'm guessing the po stripped out the threads. The car is a 91 L98 and has 40,000 miles.
I left the #2 plug untouched. Assuming I run into a thread problem, does anyone have any experience with inserting a heli-coil?
Gary: The putty material you see may be anti-sieze compound. This is a lubricant that is commonly used when you insert steel threads into aluminum material. I am confused with the term "cream colored" material. Anti-sieze is usually silver in color and has the consistancy of tooth paste. Did you find this cream colored material on the other seven plugs?
I have used a heli-coil insert before, it's not like a typical helicoil as it's a solid threaded insert. I was able to do the repair on the vehicle. It was not a vette, but it was an aluminum head.
Thanks for the reply. The other plugs did not have the cream colored putty around them and they came out without any problem. The anti-seize compound I used was silver in color. I was afraid to disturb the putty around #2 until I talked to you guys and a mechanic I trust. I hope it is not an epoxy or something similar.
I talked to my mechanic today and he has done a number of heli-coil inserts. I think I'll take it to him so that it can be cleaned out and chase the threads or what ever is needed. He'll have all the tools on hand and has had experience with such problems. I probably better hold on to my shorts.
Gary R
Gary R
Worst case you pull the head which wouldn't be the biggest deal. Good luck and let us know how it turns out.
