4+3 shifter boot removal?
Old Apr 19, 2007 | 02:24 PM
Shimy86's Avatar
Shimy86
Default 4+3 shifter boot removal?
Stupid question, how do ya get the shift **** with overdrive button off on an 86?
Old Apr 20, 2007 | 08:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Put a small flat blade screw driver between the hinging part of switch and carefully pop it apart. Unscrew the "T" bolt, counting how many turns to remove(you will need to re-install with the same amount of turns). Lift the steel block out of the shifter **** and then unscrew the ****. Pull the reverse lockout rod out and your ready to pull the shifter panel.
Old Apr 20, 2007 | 10:19 AM
Shimy86's Avatar
Shimy86
Thanks Agent! I didnt want to start prying on the button and break it. New to the forum and I've gotten more good info from you guys in a week than I got from area dealers in 3 years!!
To 4+3 shifter boot removal?
