Gasket Help Needed
Old Apr 20, 2007 | 07:01 AM
TON12350's Avatar
TON12350
Default Gasket Help Needed
Does anyone know all the gaskets involved in rebuilding a 95 LT1 motor...I know they sell kits (upper & lower) but I have a lot of the gaskets already so I want to avoid buying the entire kit...I already have:
-2 intake gaskets
-1 oil pan gasket
-1 timing cover gasket
-2 valve cover gaskets
-8 valve cover bolt grommets
-2 exhaust gaskets
-1 distributor to timing cover seal
-1 egr gasket
-2 water pump gaskets
-new throttle body w/gaskets
I think I still need:
-head gaskets
-valve seals
-thermostat gasket
-Water pump & distributor shaft o-rings
-injector o-rings
-front crankshaft seal
-water pump shaft seal
-oil filter & cooler o-rings
-rear main crankshaft seal
-oil cooler adapter gasket
-oil pump shaft retainer
-oil drain plug gasket
-rear main seal retainer gasket
-egr tube gasket (not sure about this one since I have a egr gasket already)
If anyone has a gasket kit could you check me out on these parts, I would appreciate it greatly....thanks!
Old Apr 20, 2007 | 12:00 PM
TON12350's Avatar
TON12350
Anybody rebuilding their engine soon????
Old Apr 24, 2007 | 08:40 AM
TON12350's Avatar
TON12350
Does anyone have a gasket kit?????
To Gasket Help Needed
