when do fans come on?
Except, possibly for some specialized purpose, like racing, stay away from a 160° thermostat in an L98.
RACE ON!!!
If you see 238 F on normal stoplight waits, check to see if your radiator is packed with debris!!!!!!!!!!!!!!!!!!!
Fan motors have brushes in them and the brushes have a finite life. The motor life is shortened if it runs most of the time and who wants to keep replacing fan motors all the time at $50 each? Your motor is 19 years old because you don't drive your vette very often. I drive mine, and every one of the 4 vettes I have owned every day. Also, alternators also have brushes in them and they wear out, AND the higher the current an alternator delivers, the higher temperature it runs at and the lower is its life. The main fan motor draws 14 amps.
Over the years in C4 tech, we have had 2 posters that bothered to measure HP with stock and the 160 stat and neither found any difference in HP. We have also had a number of posters show HP vs engine temp from motor oil companies that showed increasing HP with increasing engine temps. The inlet air temp is only one factor that affects engine HP, there are other factors that are more significant, like thermal efficiency.
Also, my engine never sees 238 F. The only time it did was when my mechanic purposely let it idle to confirm that it would stay within safe temps and it would rise to 238, fan comes on, temp dropped to 211 and the fan would go off. I have never sat at a stoplight long enough for my main fan to come on in the hottest summer day.
Not everyone lives in Ohio where it gets bitter cold all winter.
I ran a 160 thermostat on my 85 for the 9 years I owned it. I also installed the brass fan switch in the head that kicked the fan on at 205. I lived in Arkansas where it gets plenty cold in the winter. I never once had a problem with my heat not working nor did my fan run all the time.
If you think a low fan temp switch isnt needed in some places, Come down to florida and idle your car in traffic on a 95 degree day with the AC on.
Less power is gained from a too cool engine, for daily driving, than is lost running the fan needlessly. 'Scuse me. I have to go out to my car and empty the ice cube tray.
RACE ON!!!
From the GM manual for 1996...
"the PCM will cammand low speed fans ON at 219F and OFF at 207F and, high speed ON at 228F and OFF at 214F"
....when relay 1 is energized both fans run in low speed, when all three relays are energized both fans run at high speed...
also fans run with a/c on
I know well how a thermostat works...I never said I couldn't see it. But to your point of it being bad for the motor....Its hard to say that my 9 years and 100k miles with a 160 degree stat was hard on my motor. Especially since it would run even or pull with my 97 Z28 6speed from a roll...my 85 was stock with a gutted cat and borla cat back. It ran very well.
RACE ON!!!
The 88 Factory Manual specifies that the 88 ECM for the L-98 kicks the main fan on at 226*F and the aux. fan (if you have one) at 228*F. The dash temp readout is from a different sensor than that used by the ECM, and the different years were set-up slightly different, so the above two values are correct for most stock early L-98 C4s, plus or minus a few degrees.
While 215*F seems hot to a lot of people, it is normal. Even for much earlier vehicles. Pressure caps and anti-freeze have been used in cars like my 67 Camaro, going back well more than 40 years. This is so that the coolant temp can rise above 212*F without boiling. Water boils at 212*F (100*C) at sea level pressure (14.7lbs/sq. in.) Adding anti-freeze increases the boiling point some, and increasing the pressure in the cooling system increases it even more. That is part of why you still use anti-freeze in Hawaii and SoCal. With a proper radiator pressure cap and 50-50 mix of anti-freeze, your coolant shouldn't boil until above 265*F or more. By that time, the ECM should shut the car down due to excessive heat. By letting the temp rise above 195*F and up to 226*+/- GM is ensuring that combustion moisture and contaminents are burned off as much as possible and that the vehicle meets emmission standards.
Multi-grade motor oil is measured for viscosity based upon its flow and other aspects at two SAE determined temps. For a 5W-30 oil the winter grade of 5W is determined by the oil's viscosity at 0*F, and the upper grade 30, is determined by its viscosity at 212*F. You aren't even geting to proper oil operating viscosity temp as measured by the SAE tests until the oil hits 212*F. That is in part why others have posted about low temp operation being potentially harmful to your engine over the long run. It was designed to run at 195*F and above. My 88 usually runs an oil temp about 10* hotter that the coolant temp. At a coolant temp of 195*F the oil is at 215*F. Is it just a coincidence that oil upper visocsities are tested at 212*F and I'm within 3* of that value? I won't argue the point as few will ever change their opinions on what thermostat to use, but based upon my last statement, I feel that running with a thermostat set 30*~35* lower than design temp is not prudent. YMMV
The C4 was engineered with a reliable and efficient cooling system from the factory. If there is one significnat flaw, it is that the system easily accumulates a LOT of road debris behind the a/c condeneser and in front of the radiator. The debris hampers cooling and very large amounts of debris cannot be seen unless you remove the radiator shroud. The 85 L-98 is similar to the 88. Using simple hand tools, in just over 4 hours one Saturday morning, I removed my radiator, cleaned it inside and out, carefully rebent all fins, reinstalled, refilled, and purged. It has been running just fine in our 105*F summer days without problem.
Yes, colder inlet air is more dense and it causes an engine to be able to produce higher HP (At wide open throttle. What percent of the time you are driving your car is your throttle wide open?)
The biggest effect on engine HP is the amount of heat that the engine cooling system eliminates. IC engines run on HEAT, they convert BTU/hr into HP. Engines transfer heat from the burning fuel inside the cylinders into the coolant which is carried away and transferred to the air in the radiator. The rate of heat transfer is directly proportional to the difference in temperature between the burning fuel and the cylinder wall. So, the lower your coolant temperature is, the more heat (that is, HORSEPOWER) is transferred to the coolant. Lowering the coolant temp reduces the heat available inside the cylinder and therefore the HP. The loss due to heat transfer to the coolant FAR overrides the gain due to an increase in the air inlet density.
