Air pump eliminator bracket dimensions?
Old Apr 23, 2007 | 08:55 PM
Tom 35th anniversary's Avatar
Default Air pump eliminator bracket dimensions?
Does anyone have exact dimensions for this bracket. I would like to fab one up myself.....
Old Apr 23, 2007 | 09:12 PM
Steel Blue 91's Avatar
Steel Blue 91
Try paging forum member Agent 86 (or wait for him to chime in). He did the same thing and should have more than enough info.
Old Apr 23, 2007 | 10:15 PM
89onlyZ51's Avatar
89onlyZ51
He posted this in response to a similar request a few days ago:
http://members.shaw.ca/dankai/Air%20...Delete%20Info/
You don't have to go as fancy on the bracket - a straight piece of aluminum stock will do.
Old Apr 24, 2007 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The template prints exactly the same as original, on my printer (yours may not). I suggest if you plan on doing one, make a cardboard or plywood template to check for fit, before you cut the aluminum.
To Air pump eliminator bracket dimensions?
