It appears the alternator on my 92 LT1 has gone south. I wasn't sure if I wanted to bother with changing it myself or have the dealer do it. When I called the dealer they said it would be two hours labor + parts. Now the next time I change out an alternator on an LT1 will be the first time I've done it, but how can it be two hours labor? Am I missing something? Is there something more than disconnecting the old, remove the Serpentine belt, unbolt the old one and reverse the process to install the new one?
Thanks! Any advise would be appreciated.
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
2 hours!!!!!!
Probably take you about an hour, biggest issue is the brackets and stuff that hold the alternator and AC compressor on. The Serpentine belt is fairly easy, takes a 3/8 square drive on the tensioner. I was able to use a 3/8 drive ratch (short handle) YMMMV.
Remember where each of the brakets are and where they go back.
I think its a two hour job if you include the beer and the hand wash. Do it yourself, and you'll feel better and alot richer.
I would not go to the dealer for an alt.! You just described how to do it, half hour tops. I'm no mechanic, but I just had mine off to change my valve covers. Piece of cake. I'm sure anyone can tackle this. Good luck!
Avoid the "stealership" at all costs! You can do this job yourself. Get a FSM or Haynes manual and learn about your car. They're alot of things you can repair yourself to save money. Enjoy!
Welcome to the world of dealership flag hours. The amount of time the book says to charge for a repair. The service tech gets paid for 2 hours for that job no matter how long it takes him. This is how service techs rack up 100 hours only working 40. The more efficient the tech the more money he makes.
I've got the Service Manual. Sometimes I work on my car and sometimes I don't. The labor price the dealer quoted made my decision easier. Next question... Anyone got any advice on which alternator to buy? A lady at work has a husband that works in the parts dept at a local GM dealer and he gets me good prices on factory parts. Should I go with the factory replacement or aftermarket? Every alternator I've ever bought was a rebuilt unit from one of the major auto parts chains. Opinions?
Tip: If you are doing it with the engine hot don't lay a wrench on the plenum and then pick it up later with your bare hand.
If you forget and pick it up make sure you quickly toss it to the buddy that's watching you do it.
I think I detect the voice of experience here...
BTW, Blue... I'm on my second quasar convertible. The first was a 90 with saddle interior and tan top. The current one is a 92 with white interior and white top. They sandwiched a 99 magnetic red convertible with oak interior and tan top. The 99 was beautiful, but had all of the issues ever seen on C5's . I decided I was a C4 guy for life.
Reason: addition
I replaced the alternator on my '85 shortly after I bought it with a Duralast unit from Auto-Zone. I kept the car almost 5 years. When I got rid of it, the alternator was still working fine. I can't vouch for a unit for a LT1.
There is a small bracket that spans the AC/Alt to the manifold. That takes all of 10 minutes to remove.
There are 2 more bolts that hold the alternator to the bracket. 5 minutes. Remove the hot wire from the alt and tape it off (this saves the battery disconnect). BE CAREFUL! The stud that holds the hot wire can get ignorant. I would hit it with PB Blaster.
Remove alt. Reverse procedure.
I figure 40 minutes, tops. 2 hours? someone is smoking crack.
I'm not familiar with PB Blaster. What is that?
Thanks!
As an alternative, you can look in the Yellow Pages for alternator repair. I had mine gone through with a complete rebuild including bearings for not a lot if money....and a 2 hr turn around to boot.
Dealers and most shops use a FLAT RATE book. Look up the job, the book gives the time to charge. Most Dealers pay their mechanics by FLAT RATE, whatever is in the book is what the man gets paid for the job. If it takes him 10 minutes or 10 hours he gets the rate in the book.
Be sure and disconnect the battery before you start to remove the alternator, too.
my method avoids that little annoyance. I remove the hot lead from the alt, then tape it off. It won't ground out. The wire is stiff enough, anyway.
Then remove the tape and attach accordingly.
The only time battery disconnecting is required is if the hot wire is stuck on the alternator stud. If that is the case, a slipping wrench would be bad.
I also put a touch of antiseize on that stud... it's so damned annoying to remove when the ring connector corrodes to the stud.
I was OK with the Quasar Blue but wasn't that crazy about it.
I changed over to the chrome sawblades and it really brought the color to life. I had more than one person ask if I'd gotten the car repainted.
I agree about the chrome sawblades. Looks great. Also, I agree that the quasar blue is not complimented normally by a black interior. The saddle really looked great with that exterior color. The white is a little girlie, but hey... If you're secure in your manhood, you can pull it off!
