muffler removal
Old Apr 25, 2007 | 10:03 AM
corvettedan22's Avatar
corvettedan22
Default muffler removal
Trying to remove my mufflers, so i dont have to let some greasy shop mechanic near my car !
They are on there.
I removed the c clamp, hit it with a hammer, used a flat head screw driver and a hammer, tried the clamp further down and wacked that, heated it up with a propane torch..
She is stuck
85c4 44k
Dan
Old Apr 25, 2007 | 10:04 AM
corvettedan22
ps i want to take them off in 1 piece so if i sell the car I can put it back to stock if needed.
Old Apr 25, 2007 | 07:32 PM
m_r_donovan's Avatar
m_r_donovan
Default Cut them off
I too tried to get my stock mufflers off in one piece. It wasn't going to happen. I used a sawsall to get them off. A buyer would most likely be more attracted to a more "rugged" sound. Good Luck
Old Apr 25, 2007 | 08:04 PM
John A. Marker's Avatar
John A. Marker
Can you get ahold of a 4-1/2" grinder? If so then get a couple of cut off wheels (thin ones are about .40") and use this to cut several slots in the pipe (length wise on the pipe) about 1/2" beyond where the clamps were. Then try your hammer and screw driver ( ) to get them off. You can then weld up the slots you cut and grind them down even with the pipe. When you clamp the pipe together with the "U" clamps they often crimp the pipes. Best of luck on your project.
Old Apr 25, 2007 | 08:55 PM
corvettedan22
Sounds good, i guess ill have to try that, or just cut it where its straight, use a pipe to connect them if needed
Old Apr 25, 2007 | 09:15 PM
scott85vette's Avatar
scott85vette
Default stock mufflers
I have a set of mufflers removed from a 85 in 1986 or 87 if you ruin yours.
Old Apr 25, 2007 | 09:58 PM
ffvetteman's Avatar
ffvetteman
If they have been on there too long, they may be frozen on.
However, I have removed mufflers by putting a screwdriver on the lip and lightly tapped it in trying to seperate or expand the pipes. If you can expand it about half way around, try spraying penentrating oil, likr PB Blaster in there andtwist the muffler.
It is worth a try, but again if they are frozen they may not come off.
Old Apr 25, 2007 | 10:17 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
PBBlaster and put some heat to the bolts/nuts, let PB soak 24 hrs, mine came right off
Old Apr 26, 2007 | 07:52 AM
Joe C's Avatar
Joe C
i bought something similar to this, but mine is adjustable from 2" to 2.5" - bought it at carlisle several years ago for around $20 - mine works great...
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
note: this one is fixed at 2.25 inches
Old Apr 27, 2007 | 11:53 AM
corvettedan22
Still not off
Old Apr 27, 2007 | 12:22 PM
86 Red Neck's Avatar
86 Red Neck
only i used my roto zip with a small cut off wheel.
good luck
Old Apr 27, 2007 | 01:11 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you are not trying to save the mufflers, cut them off. If you can't drive the short pieces off the Y-pipe you are gonna have to go see that greasy mechanic!
Old Apr 27, 2007 | 09:48 PM
Ruff Rider's Avatar
Ruff Rider
They are on there.
She is stuck
85c4 44k
Dan
I could be wrong but I think the exhaust system is all One piece...
Old Apr 27, 2007 | 09:51 PM
John A. Marker
The 85 is two sections, a rear "Y" that bolts to cat and then mufflers that clamp or can be welded to the "Y".
Old Apr 27, 2007 | 10:26 PM
MrRenoman's Avatar
MrRenoman
You need an oxy/acetylene torch. It requires a lot of heat so when you try to swivel and wiggle it back and forth it loosens the muffler clamp crimp.
Old Apr 27, 2007 | 11:12 PM
Bullyj's Avatar
Bullyj
Take a Sawzaw, cut it off and be done with it.
Old Apr 28, 2007 | 06:19 PM
corvettedan22
Ok got one off
Grinded two lines, air chizeled the sides of the muffler spread open, worked it for 45 min, finaly got 1 off.
THAT THING IS HEAVY, and now chewed up !!
For the next side im going to try a smaller line (Thiner) so i can weld it back together easyier.
What angle is that muffler pipe
Old Apr 28, 2007 | 07:27 PM
78pacer's Avatar
78pacer
I admire your tenacity. I would have cut that b*tch off long ago!
Mike
Old Apr 28, 2007 | 09:14 PM
PBnf's Avatar
PBnf
Mufflers are like spark plugs, they're a replacement item. If that's all that ends up coming between you and a potential buyer, purchase a new set of OEM mufflers. But as was said earlier, most buyers would be more attracted to a better grade of muffler.
To muffler removal
