Fuel Pressure Regulator
Old Apr 25, 2007 | 02:16 PM
daniel0213's Avatar
daniel0213
Default Fuel Pressure Regulator
I am almost done buttoning this thing up. All i need is a new fuel pressure regulator. As you can see by the picture, the vaccum connection is broken off. Does anyone know what kind of regulator this is, where i can get another one, or which one is the best to use? I would like to get on from the auto parts store if possible so i can finish up tonight![IMG][/IMG]
Old Apr 25, 2007 | 02:19 PM
Square's Avatar
Square
Looks like my TPIS unit:
Old Apr 25, 2007 | 02:26 PM
daniel0213's Avatar
daniel0213
is this a stock peice or after market? Yes, i think its exactly the same!!
Old Apr 25, 2007 | 03:31 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check out the Holley unit for TPI Camaro's. I like mine
Old Apr 25, 2007 | 03:41 PM
silver86's Avatar
silver86
That's what I'm running....very easy to adjust.
Old Apr 25, 2007 | 04:07 PM
daniel0213's Avatar
daniel0213
thats the one thats like 200 bucks right?
Old Apr 25, 2007 | 04:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It looks like my HyperTech AFPR.
Is the vac fitting screwed in?
If so just install a new vac fitting; if not drill & tap the hole and install a screw-in fitting. Of course remove the AFPR before any machgining on it.
Considering that a new AFPR is around $70-$80, I'd repair that one...
Old Apr 25, 2007 | 09:41 PM
AGENT 86's Avatar
AGENT 86
More like $80
Old Apr 26, 2007 | 08:39 AM
daniel0213's Avatar
daniel0213
i just ordered the one from TPIS! Do you guys think that's a sufficient replacement?
Old Apr 26, 2007 | 08:50 AM
jmrl98's Avatar
jmrl98
I have the TPIS, and I don't like using the old diaphram. Mine went, and I had to replace it. You can get a new diaphram at some of the local parts stores (autozone, advance each had mine).
To Fuel Pressure Regulator
