ZF Transmission issue
Old Apr 25, 2007 | 11:30 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default ZF Transmission issue
What does it mean when you get a whining sound when the tranny is in neutral but goes away when the clutch pedal is depressed? ive been told the noise is intermittent.
Is this the pilot bushing going out?
Old Apr 25, 2007 | 11:43 PM
TOMS93's Avatar
TOMS93
I bet it's the throw out bearing.
Old Apr 25, 2007 | 11:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Usually it just means that you have a ZF transmission. I take it this isn't your car.
Does it only happen when the tranny is up to temp?
A bad throwout bearing on these will tend to make noise all the time since it's always rotating with the motor. The noise could get better or worse as you push the clutch in and load up the bearing, but I don't see how it'd ever be intermittent.
Old Apr 25, 2007 | 11:54 PM
TOMS93's Avatar
TOMS93
My Z06 had a bad throw out bearing and it did it intermittently. Usually when it warmed up after 15 minutes on the road. Luckily it was covered by the warranty. I'm not trying to be disrespectful, just trying to help.
Old Apr 25, 2007 | 11:58 PM
arkangel81's Avatar
arkangel81
all zf's pretty much do it, they are noisy
Old Apr 26, 2007 | 01:01 AM
Camaro350z28's Avatar
Camaro350z28
its a zf thing i wouldnt worry about it
Old Apr 26, 2007 | 02:22 AM
USAsOnlyWay's Avatar
USAsOnlyWay
4+3 started doing this, I dropped the whole thing and put it back together two nights after work. I rushed...I only replaced the pilot bushing. Its still there, its the throwout bearing...
If this noise wasn't there before and now it is, it is the throwout bearing.
Old Apr 26, 2007 | 02:48 AM
CentralCoaster
ZF and 4+3 throwout bearing are quite different. ZF bearing is attached to pressure plate and always spins.
ZF rattles in neutral, that's just how it is.
Old Apr 26, 2007 | 03:56 AM
USAsOnlyWay
Good point, I rescind my previous comment.
Old Apr 26, 2007 | 06:23 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Yes its not my car.
Not really sure. First time i was in the car I didn't notice it second time I did. It did it at startup and after the drive last nite.
Just going by what I was told. Ive had a couple 4+3 cars but no experience with a ZF.
Im guessing by the replies its normal and nothing to worry about.
Old Apr 26, 2007 | 09:34 AM
856SPEED's Avatar
856SPEED
That's right. The ZF is even worse if you have a single mass, alum. FW like I do; I have a new ZF, new clutch pressure plate, etc. and mine (with the clutch disengaged in neutral) rattles extremely loud at low RPM (idle); not to worry; did the same thing with the other ZF (black tag) I had
Old Apr 26, 2007 | 04:41 PM
Atok's Avatar
Atok
Old Apr 26, 2007 | 05:09 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Doesn't sound like a throwout bearing.
Doesn't sound like a pilot bushing.
Does sound like a gearbox thing.
Whether it's normal or not depends on the noise.
(How ya' doin', Surfie...? Your turbo project 'bout done yet?)
Larry
code5coupe
___________
I ain't easily impressed....
Old Apr 26, 2007 | 05:30 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I guess I'm lucky, my ZF6 1989 black tag doesn't whir loudly or rattle hot or cold in nuetral with the clutch out. Things that make you go....... Hmmmm?
Old Apr 26, 2007 | 06:21 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Looks like its the throwout bearing. Thanks for the help.
Old Apr 26, 2007 | 06:22 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Larry
code5coupe
___________
Turbo LT4...hmmmmm
Old Apr 27, 2007 | 10:02 AM
rocco16's Avatar
rocco16
Hmmmmm. Throwout bearings only come into play when the pedal is depressed....so a bad one would only make noise when the pedal is pushed in.....if the pedal is not depressed the throwout bearing just sits there doing nothing.
Maybe there's a cat caught in the clutch, and when the owner presses on the clutch pedal it chokes the cat?
Larry
code5coupe
__________
To ZF Transmission issue
Old Apr 27, 2007 | 10:10 AM
BADDUCK's Avatar
BADDUCK
It would have to be a rattle-snake caught in there.
Old Apr 27, 2007 | 10:39 AM
rocco16's Avatar
rocco16
Possible.
Larry
code5coupe
__________
Old Apr 27, 2007 | 10:46 AM
CentralCoaster
True for most cars. But on the ZF clutch, the throwout bearing always spins. It is clipped to the pressure plate on one end, and clipped to the clutch fork on the other. Although it won't be loaded up.
