LT1 Radiator Quest
Old Apr 26, 2007 | 09:39 AM
spinktec's Avatar
spinktec
Default LT1 Radiator Quest
I'm having trouble locating an OEM accurate radiator for my '94 vette with manual transmission. Every radiator I find has a transmisson cooler in it. Correct me if I'm wrong, but even the automatics did not have the trans cooler in the radiator. During my quest I expired all aftermarket sources (Autozone, Napa, Pep Boys, Advance Auto, Park Auto) and finally went to the dealer (believe it or not the dealer was the cheapest). Unfortunately, I still ended up with a trans cooler in the radiator. I did a little more checking and found the original GM part number 52460411 is obsolete. As far as I've found GM doesn't show that it has been superceded, it only shows the new GM part number 52473260. See pics
Does anyone have a source for a new radiator without a trans cooler that is not a $400 plus, 3 row, all aluminum, etc., etc.
Old Apr 26, 2007 | 10:45 AM
CFI-EFI's Avatar
CFI-EFI
What is your objection to the trans cooler? It isn't in the way. It doesn't compromise the cooling by the radiator. I can't imagine the trans cooler in the radiator was done away with for LT1 automatics, but I admit I know little of the later C4 cars. All of the replacement industry has reduced their C4 radiator inventory to two part numbers, 1984 - 1989, and 1990 and up. There is no good reason to manufacture, stock, and inventory, double the part numbers when one works for all.
RACE ON!!!
Old Apr 26, 2007 | 10:58 AM
Jerris's Avatar
Jerris
I do not think there were any LT1 automatics made by GM in 92, they are all ZF 6 speeds.
I agree with CFI, go ahead and use the one pictured, it will work just fine and there will be no issues of leaks as the cooler is not open inside the radiator.
If you do fine the correct one it should be a little cheaper that the automatic one.
There are several years that corvetts have the same dimensions on the radiator so there should be no fitment issues.
Old Apr 26, 2007 | 11:24 AM
toptechx6's Avatar
toptechx6
Not sure where you got that idea, there are lots of 92's with the A4.
Old Apr 26, 2007 | 11:26 AM
CFI-EFI's Avatar
CFI-EFI
No automatic Corvettes in 1992? That seems unlikely.
RACE ON!!!
Old Apr 26, 2007 | 11:30 AM
SJW's Avatar
SJW
9,117 to be precise...
Be well,
SJW
Old Apr 26, 2007 | 11:47 AM
ScaryFast's Avatar
ScaryFast
DeWitt's (dewitts.com) has stock replacement radiators without the trans cooler.
I don't know what he charges.
If you aren't set on a new one you can have my old one from my C4 6-speed cheap. I put in a dual core with an engine oil cooler since my C4 is now track only. It's in great shape, no leaks. Pics if you want them.
But of course I have no idea how long they are supposed to last nor how much life mine has in it.
Old Apr 27, 2007 | 09:01 AM
spinktec's Avatar
spinktec
I don't see how it a radiator could go unaffected by such an obstruction. If you compare the two you'd find the trans cooler unit has a solid plate with about 3/32 area around the edge for coolant to flow from the outlet of the radiator. In addition, the trans cooler adds a little more complexity and two more future leak points. To be fair I accept the idea that it is less expensive to manufacture a single part to cover multiple applications; as long as it is an aftermarket manufacturer. I don't accept the same from GM.
To clarify my statement regarding automatics: I was speaking under the assumption that 1992 and above automatics had a liquid to air trans cooler mounted under the car, not a liquid to liquid cooler integral inside the radiator. If I'm wrong please correct me, because this is my main complaint against the change by GM. If no 92+ corvette uses an internal cooler (not even the automatics) and they put it in because the OEM manufacturer doesn't make a radiator without a trans cooler then shame on GM.
Old Apr 27, 2007 | 09:26 AM
Z06_BluByU's Avatar
Z06_BluByU
Just a few clarifications:
1. 92 did come in automatic
2. All LT1 automatics came with an integral tranny cooler in the radiator (liquid to liquid)
Old Apr 27, 2007 | 12:01 PM
CFI-EFI's Avatar
CFI-EFI
The clearance isn't as tight as you think. If there were a flow restriction with the coolers installed, GM would have figured out a different/better way to cool the auto and 4+3 transmissions.
Consider yourself corrected. If that were the case I would have posted differently.
And shame on you for making false assumptions. Besides, the radiator fits from 1990 to 1996. Why create more inventory problems, needlessly?
RACE ON!!!
Old Apr 27, 2007 | 06:02 PM
spinktec's Avatar
spinktec
I stand corrected regarding the liquid to liquid trans cooler used in automatics.
Just to be clear, I'm not making assumptions, I'm asking a simple question about OEM components from the only people who seem to know the answer (this forum). I asked my authentic GM parts distributors and they more or less swore to me that there was, and always has been a single part number for that radiator. Logical conclusion is then: if my radiator was that single part, and it did not have a trans cooler, then no radiators had trans coolers. Apparently this is not true and I'm glad to know it.
Regarding the flow obstruction caused by the trans cooler. I just reviewed the position of the trans cooler in the radiator and I reassert that there is an unquestionable flow reduction affect over not having a trans cooler installed. Of course I expect the radiator will function adequately; and after all isn't that why I bought a Corvette instead of a Volvo, because I want a high adequacy vehicle not a high performance vehicle? No!
Old Apr 27, 2007 | 06:17 PM
spinktec's Avatar
spinktec
I started this quest for a radiator that began leaking as a result of settling on jack stands while I was installing the headers, exhaust, ignition, urethane bushings, and 3.73 rear end. I looked at, and still really do want a DeWitts radiator, but I just can't justify the cost until the next round of mods that will require the engine have an upgraded cooling system.
This radiator cost me $170 to my door from GM parts direct. And as I said, it was less expensive and it has a much better fit and finish than the other three radiators I looked at from the aftermarket stores (as I mentioned they all had trans coolers too).
Old Apr 27, 2007 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
Any more, you mean?
There must be a fine line between a "logical conclusion" and an assumption.
Of course the water flows over the cooler coils, otherwise it wouldn't cool. I guess the term "flow restriction" is relative. When considering the "flow restriction" did you also consider the flow PATH of the coolant? Most of the coolant doesn't flow the length of the cooler.
RACE ON!!!
Old Apr 27, 2007 | 07:23 PM
spinktec's Avatar
spinktec
Originally Posted by CFI-EFI
Any more, you mean?
RACE ON!!!
I posted this discussion in is Tech/Perf forum to avoid these types of inane, infantile responses. Thanks CFI-EFI, you've been a great help, but I'd love to hear from ANYONE else.
Old Apr 27, 2007 | 07:32 PM
CFI-EFI's Avatar
CFI-EFI
Well the heck with you too, but when you make inane statements about "flow restrictions" that the industry hasn't seen as a problem, it is ME that you at MOST likely to hear from. Obviously you DIDN'T consider the flow route when you started the inane comments.
RACE ON!!!
Old Apr 27, 2007 | 07:44 PM
z28cp's Avatar
z28cp
I replaced the radiator in my 94 6-spd coupe last year. Found the same thing you did, only the one part number available. I have had no issues with it, and the car gets autocrossed frequently. Have had no cooling issues at all.
Just my experience.
DaveZ.
Old Apr 27, 2007 | 09:25 PM
Ruff Rider's Avatar
Ruff Rider
You can have my stock one for free as long as you pay for the shipping... I got a Dewitt this past X-Mass G.P. sale, just waiting to get my hot came package.....
To LT1 Radiator Quest
Old Apr 27, 2007 | 11:13 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I understand your concern. The flat factory GM coolers do in fact restrict the outlet port but I also have to agree with CFI-EFI, that it doesn't seem to cause any problems.
When we made our cooler we decided to build it offset, so the cooler would sit closer to the center of the tank and block less of the coolant flow. The photo below shows what I'm talking about. Note how close to the tank edge the GM 3 plate one is compared to our 7 plate unit.
Oh, and here is the manual version you are seeking
Old Apr 27, 2007 | 11:46 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
The photo below is actually a C5 radiator but it shows just how much that cooler blocks the port. If we insert the tube into the hole 1/8" deep, the port will be completely blocked.
Old Apr 28, 2007 | 02:10 AM
96GS#007's Avatar
96GS#007
GM discontinued the manual transmission specific radiator p/n years ago. Since that time, one part number has been/is available. Since the automatic transmission equipped cars need a cooler (go look at any C4 with an automatic transmission and they have the cooler in the radiator), guess which part number it is that was continued.
