86 intermitent starting problems
Old Apr 26, 2007 | 09:48 PM
bill83c4's Avatar
bill83c4
Default 86 intermitent starting problems
wondering if anybody has experienced a problem similiar to mine or can help identify it. Every once in a while (twice a month or so) the engine won't turn over. i replaced the starter last summer thinking that was cause. could this be a problem with the clutch switch, starter...... any help is appreciated.
Old Apr 27, 2007 | 12:17 AM
David-F's Avatar
David-F
You will need to hook up a test light to the purple wire going to the starter solenoid and see if you are getting power to the starter when it is not starting once you know this you will have a idea of where you need to look next. I do suspect the clutch safty switch. One thing you can do is next time you have a problem leave the ign. switch in crank position set the park brake shift it into neutral then pump the clutch pedal if this starts the car then you will have to look at the clutch safty switch if this doesn't help you will need to hook that light up and go from there.
David Fulcher
Old Apr 27, 2007 | 12:27 AM
zapitbullseye's Avatar
zapitbullseye
Also, is it temperature related? Does it do it when hot or cold? You could be getting a heat soaked starter if it's doing it hot. Just throwing ideas........
Old Apr 27, 2007 | 12:55 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default no start
try taking the mat out of the driver's side, the clutch switch may be out of adjustment, and the mat may inhibit full clutch travel
Old Apr 27, 2007 | 07:46 AM
ittybittyfds's Avatar
ittybittyfds
i have the same problem on my 85 and i was told that its the clutch engage switch
To 86 intermitent starting problems
