Zf-6
Old Apr 27, 2007 | 10:43 AM
Timo's Avatar
Timo
Default Zf-6
How much torgue the ZF can handle ? What is the limit ?
Old Apr 27, 2007 | 10:46 AM
AKS Racing's Avatar
AKS Racing
I don't know the ratings, but I am past 760 ft-lbs at the wheels (Jul '07 MD run) and it is staying together. But... I am not doing 6000RPM clutch drops either.
Aaron
Old Apr 27, 2007 | 10:52 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Aaron
How often do you go WOT??
I ask because my theory is that any driveline component has a finite limit on the time it can endure any set amount of stress.
In other words, say the ZF in your car has a limit of 4 hours at 760ft/lbs. If you subject the gearbox to six WOT (760ft/lbs), of 20 seconds duration each, every year, the gearbox will last 120 years before something breaks.
If you subject it to 3 minute durations, eighteen times a week, then it will last less than 6 months. (both examples are extremes, of course)
Every driveline component, if used, will fail eventually. The frequency which you use all the power will determne how long they will last.
I love theories.
Larry
code5coupe
_________)
I ain't easily impressed....
Old Apr 27, 2007 | 01:47 PM
AKS Racing's Avatar
AKS Racing
In other words, say the ZF in your car has a limit of 4 hours at 760ft/lbs. If you subject the gearbox to six WOT (760ft/lbs), of 20 seconds duration each, every year, the gearbox will last 120 years before something breaks. If you subject it to 3 minute durations, eighteen times a week, then it will last less than 6 months. (both examples are extremes, of course). Every driveline component, if used, will fail eventually. The frequency which you use all the power will determne how long they will last.
I love theories.
Larry
code5coupe
You may have me there, as this is more of a pleasure vehicle, and as such, it may sit for two / three weeks, then be taken out Sat/Sun. But... when I drive it, I do hammer on it pretty hard (after all is nice and warm, of course).
I am concerned that several items may be loosing life, as the above Mustang Dyno run was done at just over 10 psi. I changed to where I am steadily running in the mid 20s, which is significantly more power. The weak link will identify itself, of this I am sure.
Aaron
Old Apr 27, 2007 | 05:28 PM
88BlackZ-51's Avatar
88BlackZ-51
I know guys with 500rwtq N/A with there ZF's, and no issues for years.
Old Apr 27, 2007 | 08:13 PM
tpi 421 vette's Avatar
tpi 421 vette
I had 790 ft/lbs (numbers in sig) at the tires, and have blown up everything behind the trans,before the 9", but the ZF still holds up. I drag race mine with 28x12.5x15 et streets with nitrous, and the trans has held up fine.
Old Apr 28, 2007 | 12:22 PM
Archaea's Avatar
Archaea
THAT is amazing to me!
The ZF apparently is much stronger than I thought.
I'd kinda always heard you didn't want more than about 450Ft/Lbs of torque for this tranny if driving hard.
Old Apr 28, 2007 | 04:01 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
True, but a clutch drop will stress it more than a WOT run, it's dumping the momentum of the bottom end onto the trans all at once. And of course in 1st gear, everything downstream of 1st gear will see way more torque than for 2,3,4,etc.
Old Apr 28, 2007 | 04:08 PM
CentralCoaster
Also some materials will never fail if they aren't loaded up past their endurance limit. This might only be maybe 25% of it's ultimate strengh though, and less than the fatigue strength which means it will break after some set number of cycles.
But basically the question isn't how much can the ZF6 hold.. It should be how long will it last at X power output? Its enough for me anyways.
Old Aug 2, 2008 | 06:31 PM
Pals92C4's Avatar
Pals92C4
I know this is an old post, but the answer is in the Service Manual.
Rated to 450 ft lbs.
Old Aug 3, 2008 | 11:36 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
The early ZFs are rated at 450 (black tag) and the later ones at 400 (blue tag).
Old Aug 3, 2008 | 06:51 PM
89FX3's Avatar
89FX3
My understanding is early "black tag" ZF-6 trannies were conservatively rated at 450 ft-lbs torque; later "blue tag" ZF-6 trannies I thought were rated at 425 ft-lbs but I could be wrong.
I have no idea what the differences are though i have one of each.
I emphasize the "conservative" nature of these ratings since the ZF-6 was 1) designed to handle the ZR-1 engines and 2) used by Callaway & Doug Rippie in a lot of their custom builds without modification.
Check with Bill Boudreaux (sp?) at zfdoc.com if you want the true skinny.
Old Aug 3, 2008 | 07:32 PM
89FX3's Avatar
89FX3
Aaron
I also think hearing real time experience from knowledgable posters like AKS Racing/tpi 421 vette and 88BlackZ-51 is more important than nominally assigned torque ratings.
Given that type of reported experience and the Callaway & Doug Rippie program useage of the ZF-6 I've been kinda surprised that some have expressed an interest in changing their ZF-6 for a T-56.
To be sure the T-56 is a great tranny (I have one in my 94 Viper) but I don't find it anywhere near as 'civilized' as the ZF-6.
Then again I don't track my cars.
To Zf-6
