tuning advice + dyno scan
I am in the middle of tuning using tuner pro RT and autoprom, and I have an issue, just about sorted all of the ve tables usuing VE master and AF is between 14. and 15, so quite pleased there, the problem that I have yet to sort out is..... driving along say 30 mph steady throttle, if I very slightly squeeze the throttle ( to accelerate very slightly, slight incline for example) the AF momentarily goes lean ( AFR =18 + ) just for a second or two then it settles back to 14ish and stays there ( sometimes if the car is hot it will spit back ),
I guess that there is an "enrich" table that needs adjusting but which one is it?
I am new to tuning and I am pleased with what I have managed so far just could do with a little help, below is a print out from the dyno today.
Many thanks in advance.
Adrian
A B M
Adrian
A B M
Curious. Why are you using 24's? FYI. I have a good friend with a 355/MR/GM Fastburn heads/ZZ409. His combo is making 390rwhp, and he is using 42's. I think the main reason why your graph starts to drop off like an L-98 instead of maintaining that nice Miniram curve is due to your fuel injectors. You need at least 36's imo.
But that is not the problem that I am trying to solve at the moment , I am trying to ascertain what "enrich" table that I have to adjust to get rid of the 2 second lean spot just as I squeeze the throttle.
Thanks in advance
Adrian
A B M
Start by boosting up "AE delta TPS multi vs Delta TPS". When do you see the lean spot? just when you apply TPS ( fast open the TB ), or 1-2 second after you open the TB?
It happens the second that I move the throttle and settles back to 14ish 1 to 2 seconds later.
Many thanks
Adrian
A B M
