1990 Infl Rest Light On ?
Old Jun 5, 2007 | 05:54 PM
kad92's Avatar
kad92
2nd Gear
Default infl rest sensors
i know this is a very basic question, but where are the sensors????
Old Jun 6, 2007 | 06:32 AM
Joe's Avatar
Joe
Default location
They are bolted to the top of the frame , driver side you must remove the fender and the battery and you can get to it , a bright yellow wire goes to the sensor's , if you remove the rubber grommet from the fire wall there is a plug to unplug the sensor , the passenger side is about the same place !
Hope this is some help , good luck !
