WINALDL setup?!??!?!
Old Apr 30, 2007 | 10:30 PM
TPI84GMC's Avatar
TPI84GMC
Default WINALDL setup?!??!?!
I have an 88 ecm and I can only get the first 5 or so lines to give me data in WINALDL. what else do i have to setup besides telling it the ecm #??? 1227165 also is there any list of what all the information means??
Old Apr 30, 2007 | 11:12 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
On my 87 I have to have a 10K resistor in the cable between pins A & B to get data flowing. If you've tried that, you might also experiment with different baud rates in WINALDL.
Gary
Old May 1, 2007 | 10:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Since you have the 165 ecm, I would look at using Moates software or Datamaster. Both are free, but Datamaster will cost you if you want more than the 20 free trial sessions.
Old May 1, 2007 | 10:54 PM
TPI84GMC's Avatar
TPI84GMC
What do I download on the MOATES site? there are a few programs listed including protuner rt which I tried and couldnt get to work either.
Old May 1, 2007 | 11:33 PM
AGENT 86's Avatar
AGENT 86
It's been a while since I used the moates software so I don't remember what is what on his site. What cable are you using ??
Old May 2, 2007 | 11:49 AM
TPI84GMC's Avatar
TPI84GMC
I got it from aldlcable.com the OBD1 serial cable
http://www.aldlcable.com/sc/details.asp?item=aldlobd1
I just looed at it again and it says something about a resistor on the cable end can be repositioned between ports A and B for late 80s cars. I'll have to look at it again today and see if i can get it to work.
Old May 2, 2007 | 11:05 PM
TPI84GMC's Avatar
TPI84GMC
Default WinALDL DRP occured, o2 sensor, closed loop???
So I got my WinALDL to work and read everything. What does DRP Occured mean in the WM2 Flag data tab? And it never goes to closed loop even after running the engine for 5 min at operating temp. WHat should my O2 sensor read? it only goes as high as about .85.
Old May 3, 2007 | 02:22 PM
ghlkal's Avatar
ghlkal
You need it
Gary
Old May 4, 2007 | 12:37 AM
TPI84GMC's Avatar
TPI84GMC
Yeah as soon as i put it in the right place it started streams of data that I dont understand!
Old May 4, 2007 | 08:14 AM
AGENT 86's Avatar
AGENT 86
Forget WinALD, now that you have the 10k resistor in, try Datamaster.
http://www.ttspowersystems.com/softw...2/setup-32.exe
To WINALDL setup?!??!?!
