lowing C4 and alignment
Old May 1, 2007 | 02:07 AM
carriker's Avatar
carriker
Default lowing C4 and alignment
So I'm planning on lowering soon, about an inch all the way around. Just put on Grandsport wheels and for some reason those fatties make the car look like it's sitting too high, even though it has exactly the same wheel gap. Anyway, I will lower it and take it to a shop to get it aligned. My question is, how do they align it? They can't use stock corvette specs. Do I need to give them specs, or can I say "Here's my car, align it."? What do I need to do?
Thanks, -Matt
Old May 1, 2007 | 02:11 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I take the Vette in to the shop I just ask them to align it.
Unless you want a custom setup that is enough.
Old May 1, 2007 | 02:23 AM
carriker's Avatar
carriker
Pardon my ignorance..... but how do they know what to do?
Old May 1, 2007 | 09:59 AM
Aardwolf's Avatar
Aardwolf
They use the stock alignment specs unless you want something more. VB&P has some advanced street specs on their page. The car being lowered doesn't mean it can't have a stock alignment spec.
Old May 1, 2007 | 10:17 AM
LD85's Avatar
LD85
Call first to make sure they can handle 315's if you have them.
Also make sure they can handle a 17" wheel by clamping on the OD not spiking the ID lip of the rim.
Old May 1, 2007 | 10:23 AM
carriker's Avatar
carriker
They can use stock specs??? Really? I don't want something more, I just want my new 315s to wear evenly after I lower it.
BTW, anyone have any problem with rubbing after lowering a car with this big of tires on it?
Old May 1, 2007 | 12:09 PM
Bad Karma's Avatar
Bad Karma
Yes, they stock specs are what's going to keep the tire wear even. The width doesn't effect the angles they adjust for alignment. Toe, camber, caster, etc are the same if you are aligning a 225 or a 315.
Old May 1, 2007 | 12:14 PM
dadsC4's Avatar
dadsC4
These guys are right. They will use the same ANGLES the vehicle will just be at a different HEIGHT.
Old May 1, 2007 | 01:57 PM
KCHOTBOAT's Avatar
KCHOTBOAT
The problem I ran into was finding a shop that could get the car on the rack in the first place. I ended up at a Honda dealership to have the alignment done.
Old May 1, 2007 | 02:32 PM
Snakecharmer383's Avatar
Snakecharmer383
I was thinking of doing this also. Let me know what you pay at the shop and total investment for this. Send me a PM if you don't mind!! My car seems like it squats HARD when I'm on it, I think I lower it I will have big rub problems!!
Then post up some pics when done!
Old May 1, 2007 | 02:56 PM
carriker's Avatar
carriker
I'm not talking about the width of my tires, I'm talking about my car being low. I'm amazed that they use the same specs to align it even if it's lowered.
Will do.
Old May 1, 2007 | 04:11 PM
ScaryFast's Avatar
ScaryFast
Why? How are you lowering it? You realize that depending how this is done the car could handle poorly, right?
Old May 1, 2007 | 04:15 PM
Mojave's Avatar
Mojave
If you are going to auto-x your car, for the love of god don't use stock specs. I would recommend between -.5 and -1.0 camber (more = better), with a lot of caster, as much as possible really, and zero toe. -1.0 camber won't wear the tires too bad for daily driving, and it will keep you from destroying the outsides of the tires while auto-xing. If you really want to improve turn it, dial in some toe-out (up to 1/8").
For the rear, some toe in is good, I think I have 1/8 (I can't remmeber exactly...). For rear camber, you want less than the front, say -.25 to -.5.
My car has front: -2.3 camber, 7.5 caster, and 1/8" toe out. Rear is -1.3 camber and 1/8" toe in.
Old May 1, 2007 | 05:27 PM
Aardwolf's Avatar
Aardwolf
What's the good way, and the bad way?
Old May 1, 2007 | 06:21 PM
dadsC4's Avatar
dadsC4
The best way would be to find lowered spindle assemblies. That way your suspension wouldn't be altered, otherwise you are looking at modifying your springs. Please don't do that. I don't think you even can if you have the lateral leaf. Lowered spindles are an easy swap, if you can find a set, you shouldn't even have to get it aligned. All it will do is move your wheels an inch or so into the wheel wells. Keeping your angles the same.
Old May 1, 2007 | 06:27 PM
Aardwolf's Avatar
Aardwolf
There are different thickness shims in there depending on year and if it's a vert, so the ones with thinner shims handle worse? That doesn't make sense.
There is a company making lowering spindles??? I've never seen one!
Old May 1, 2007 | 06:35 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
No such thing available. Please correct me if I'm wrong. And you can only go so far before the lower ball joints scrape the wheel.
You don't modify the springs. You simply move the front spring closer to the car by using shorter wedges and removing factory shims. And the rear spring you put longer bolts on to move the spring lower and everything else connected to it.
Yes, using the bolts and wedges will change the suspension geometry slightly. Is this a bad thing? Either you have some insight to the castor/camber/toe curves and what's best for racing, or you are assuming GM's stock location is the only way to do it. That's a poor basis in my experience, since GM's design priorities are usually not the same as ours, and the performance is often compromised for CYA/liability/dumbass owners, etc. This assuming they had it all figured out in the first place, which doesn't seem to be the case as they redesigned the whole front end in 88.
I appreciate your trying to help though.
Here's a how to on the wedge/bolt kit install:
http://webpages.charter.net/khasting...ng_backup.html
To lowing C4 and alignment
Old May 1, 2007 | 06:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Will do.
You are lowering the body not the axles. Wheel/tire height does make a difference but very little.
Old May 1, 2007 | 07:57 PM
carriker's Avatar
carriker
Modifying springs? Lowered spindles? C'mon, what are you talking about? All you need is 2 bolts, 2 nuts, 2 pads and the car gets lower. That's what I'm going to do.
I know I'm lowering the body. The new wheel/tire height is the same as my old wheel/tire height, so it makes zero difference.
I also just realized I wrote "lowing" in the title of this thread.:o
Oh well...
Old May 1, 2007 | 07:59 PM
CentralCoaster
Purpose of the alignment is to align the tires with the road. Lowering the car moves everything around a little, so you have to realign it to get back to the factory specs.
