Wipers
Old May 1, 2007 | 09:59 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Default Wipers
The wipers on my 88 bump into one another sometimes. most of the time there just fine. But when on intermitant they bump every so often. Any idea's?
Old May 1, 2007 | 11:12 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
There are adjusters under the screen on the bars that guide the wipers. Turn on the wipers and kill ign. power at the point they are clashing.
Remove the screens and loosen the bolts (on drivers side over wiper motor) and you will be able to make minor adjustments in the wipers. Adjust until satisfied.
You may also want to pull the arms and make sure the spline is not stripped in there. That will also cause some clash. Using a 19" blade on the drivers side will help too.
