charging voltage
Old May 1, 2007 | 09:33 PM
gator79's Avatar
gator79
Default charging voltage
I have a 93 that often shows 14.3- 14.1 on the amp gauge it hardly ever gets below 13.7. is this normal? also the sys light flashes I guess I need to get the codes, the battery is new
Old May 1, 2007 | 10:36 PM
jfb's Avatar
jfb
Those voltages are normal.
Old May 2, 2007 | 07:29 AM
runner140*'s Avatar
runner140*
Sounds like your new battery could be low. When installing a new battery, first put a charge on it. They sometimes lay around a parts store for some time before they are purchased.
Your alternator is fine.
Old May 2, 2007 | 07:43 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If your alternator is good, it sounds o. k., it should bring your new battery to a good charge level. When you first start up does your amp gauge read up around 14.5 and then drop back to the 14.0 after you run for a while?
Old May 2, 2007 | 08:08 AM
shop14's Avatar
shop14
that should be fine,ive seen better #s.my wifes 95 never drops below14.5 runs a steady 14.7 and 14.9 first start in the morning.
Old May 2, 2007 | 09:06 PM
gator79's Avatar
gator79
yes it does, just seemed a little high, I have worked on Fords for 30 years and normal charging system voltage is closer to 13 volts
Old May 2, 2007 | 10:25 PM
jfb's Avatar
jfb
C4 alternators are designed for 14.7 volts output, alternator cold and the voltage drops with increasing temperature to 13.7 volts. The dash voltmeter reads 0.3 volts low due to the voltage drop of 0.3 volts across the ignition switch contact.
To charging voltage
