Holley Stealth Ram
Old May 2, 2007 | 07:23 PM
jghmczo6's Avatar
jghmczo6
Default Holley Stealth Ram
Has anyone had / have this system on their C4?
Stealth Ram MPFI System, 24 lb/hr Injectors,300-385 HP Range
Polished Finish. What is the performance difference over the stock TPI
intake. I was told I needed to remove the restrictive intake system looked at the SR and while the performance comments are good, my understanding it is a nightmare to avoid gasket leaking.
All comments welcome
Old May 2, 2007 | 08:09 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Getting read to install, HSR build (see pics), this is the HSR that fits under a stock c4 hood, no mods required..
Old May 2, 2007 | 10:15 PM
89onlyZ51's Avatar
89onlyZ51
Where did you get that plenum, or did you fab it yourself? Also, doesn't the HSR require swapping out distributors to the small type with external coil?
Old May 2, 2007 | 11:44 PM
vinnies87's Avatar
vinnies87
Plenum custom made....yes, if you look you'll see the small dist, setup with msd and coil
Old May 3, 2007 | 12:44 AM
rodj's Avatar
rodj
intake.
www.stealthram.com for info
http://www.eecis.udel.edu/~davis/z28/winter01/
dyno/dyno021105/webpage021105.html
http://www.thirdgen.org/techboard/al...gal-whats.html
?highlight=vette+stealth+ram
Old May 3, 2007 | 02:27 AM
LD85's Avatar
LD85
You know,,, you can run your fuel lines into the front and move the hard metal cross-over line to the rear!?
It all fits like that
Old May 3, 2007 | 02:40 AM
davidnclearlaketx's Avatar
davidnclearlaketx
Gorgeous setup!!
Old May 3, 2007 | 12:08 PM
vinnies87's Avatar
vinnies87
Duh,,,, I never though of that... great idea... thanks, guess the only thing is to remake the braided fuel lines... i'm getting better at that too...
thanks for the tip, i'll work on it ....
thanks
vinnie
Old May 3, 2007 | 06:16 PM
jghmczo6's Avatar
jghmczo6
Will this fit under a '90 C4 hood without modifications as I have vortec
heads on the 350?
Jegs link part #510-91603201
http://www.jegs.com/webapp/wcs/store...51443_-1_10299
Thanks for all the help
Old May 3, 2007 | 07:25 PM
vinnies87's Avatar
vinnies87
No, no without modifications
Old May 3, 2007 | 07:59 PM
jghmczo6's Avatar
jghmczo6
What modifications would be required, hood, intake?
Old May 3, 2007 | 08:03 PM
LD85's Avatar
LD85
Simplest option #1 = buying the fabbed plenum like Vinnies @ $ 300 for the plenum
Option # 2 = JOBY's = cost of welding and grinding
Option # 3 = new hi-rise Hood = $1300
Option # 4 = what I did, you provide the plneum I machine it= $500
http://forums.corvetteforum.com/show...post1556252448
eric_daniel's Avatar
eric_daniel
What's the hp difference in this and the accel superram setup?
Old May 3, 2007 | 08:12 PM
LD85's Avatar
LD85
I hope to hit the dyno for the first time time before the end of June, my motor is out of the car right now.
Old May 4, 2007 | 12:34 AM
vinnies87's Avatar
vinnies87
LD: you said a mouth full... oh yea, i moved the crossover tube to the back, fit like a charm... now just have to remake the fuel lines, but great thing is that they are short and nothing near the injectors... thanks again for the suggestion....
Old May 4, 2007 | 09:46 AM
LD85's Avatar
LD85
No problem, CF needs a sticky regarding the MR, SR and HSR for sure.
Old May 4, 2007 | 11:20 AM
SCCA VETTE's Avatar
SCCA VETTE
That is one SWEEET setup. hopefully some day mine can look half that good.
To Holley Stealth Ram
Old May 4, 2007 | 12:14 PM
DanZ51's Avatar
DanZ51
OK Vinnie, Sorry if I missed this before but..
Who made your plenum?
Old May 4, 2007 | 12:32 PM
billybonesmusic's Avatar
billybonesmusic
I think that beats my RPM AIR GAP and 750 CFM Demon
Old May 6, 2007 | 06:36 PM
Slalom4me's Avatar
Slalom4me
It may have been a DIY kit or RTR item fabricated by Frank at Fuel Injector Clinic.
To the best of my knowledge, GrumpyVette preceeded others with the
creation of a modified HSR plenum for fitment under a stock C4 hood.
The modified plenum was a source of many heated threads beginnning
in '03. Those archived threads are available for review through the
use of the CF Advanced Search feature.
Option # 4 = What I did, you provide the plenum, I machine it= $500
Read about LD85's Holley Stealth Ram
Keep in mind that Option #3 (new hood) does not include shipping
or the cost to prep and paint the new hood. My vote is that changing
the hood would lead to two or more thousand dollars being spent.
Read LD85's thread in the link above and follow along as he fabricates
his version of the plenum. My vote is that appearance of the final
product speaks for itself.
To the best of my knowledge, Holley/Weiand only sells the Stealth Ram
as a package consisting of the base & plenum, AFAIK, the base is not
sold separately. Therefore, might as well make use of the included
plenum rather than have it collecting dust on a shelf.
If a vendor modified the thermostat housing as part of a plenum
package, it looks like an interested party starting with an OEM TPI
would need the following to swap to an HSR:
- an HSR intake and the HSR fuel rails
- work to modify the plenum and thermostat housing
- small dist & remote coil
- suitable injectors (=> 24# rating)
- fittings
A discussion of miscellaneous HSR considerations occured in a post
in this thread
(ignore the Super Ram title of the thread). In addition
to part numbers for conventional heads, the intake p/n#'s for Vortec
heads is also listed.
With part numbers from the links provided, a budget for the swap can
be compiled by doing a little research at forum supporter Jegs or your
favorite performance parts supplier.
