Abnormal Brake Wear
Old May 5, 2007 | 06:15 PM
Fast Eddiz's Avatar
Fast Eddiz
Default Abnormal Brake Wear
What would cause the left front brake pad to wear out faster than the others, way faster. Right front and rear pads showed normal wear, where as the left front was completly shot, needed to replace the rotor.
Old May 5, 2007 | 06:52 PM
Sidney004's Avatar
Sidney004
Most likely a stuck piston. New seals and dust boots, clean the pistons thorourghly and inspect the bores. It is a pretty easy job.
Old May 6, 2007 | 10:29 AM
Goldcylon's Avatar
Goldcylon
A stuck or lazy caliper
Old May 6, 2007 | 10:31 AM
Pete K's Avatar
Pete K
Be sure to completely clean and lightly lube the area the caliper slides on when you do the repair.
To Abnormal Brake Wear
