MAF sensor plug???
Old May 6, 2007 | 08:34 PM
pack24's Avatar
pack24
Default MAF sensor plug???
I bought an 86 with the TPI removed and a standard manifold and carb. I've posted on all the other stuff and recieved excellent respones.
One more question. I've found all the plugs for everything on the manifold but can't seem to find the MAF plug. What harness does it come from? right bank, left bank, front of car, left or right side. How many wires? Diagrams show 5, is this correct? I checked for an hour today trying to find it.
Any help where else to look would be great.
Old May 6, 2007 | 09:13 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default maf plug
maf plug goes down the upper right valve cover near the injector wires. The connector is a strange little plug with the 5 wires, and have smaller pins/sockets. it will be a little longer, and kind of hang out there. I'ts possible that the previous owner could have run thm down the left side, and /or cut the connector off.
Old May 6, 2007 | 09:22 PM
Repzard's Avatar
Repzard
It looks kinda like this but 5 wires
credit chevythunder.com for picture
Old May 6, 2007 | 09:26 PM
pack24's Avatar
pack24
Is it wound in with the injector harness? Nothing else on the car was cut.I don't see him cutting just that plug. But you never know. Is it black like everything else?
Old May 6, 2007 | 10:00 PM
Repzard's Avatar
Repzard
This may help you out
The color of the wires are as followed
Black\White - pin 1
Black\Pink - pin 2
Dark green - pin 3
Dark Blue- pin 4
Purple - pin 5
To MAF sensor plug???
