" what preasure radiator cap please?"
Old May 7, 2007 | 06:07 AM
sxyvet's Avatar
sxyvet
Default " what preasure radiator cap please?"
hi there guys,
i was just wandering what preasure radiator cap to use/run with my worked L98 1991 corvette please?
is there any preformance gain running lower or higher preasure cap at all please?
any help would be great thanks!
cheers
glen
Australia
Old May 7, 2007 | 06:27 AM
LT4BUD's Avatar
LT4BUD
Originally Posted by sxyvet
hi there guys,
cheers
glen
Australia
I think most including myself are running stock...
You would NOT want to run a lower pressure cap....
Running a higher pressure cap would stress hoses, gaskets, radiator, etc. and I have never been able to find a definitive answer regarding any limitations for our cars...but there are some possible disasters from going too high
Benefits of higher pressure included slightly better heat transfer (cooling) at the higher pressure, more safety against steam formation if your engine does overheat, possibility of slight weight reduction with a smaller overflow tank,.....
More ideas ???
Old May 7, 2007 | 06:57 AM
sxyvet's Avatar
sxyvet
hi lt4bud,
how are ya!
thanks for your reply mate!
so what is the standard preasure radiator cap anyway please??
thanks
glen
Old May 7, 2007 | 07:54 AM
xflagz51's Avatar
xflagz51
The standard L-98's came with a 15 PSI cap and the Z-51 cars came with a 17 PSI cap. The 17 pound cap will allow you to run higher coolant temps without boiling, however you putting making the hoses work harder which can be dangerous. As in a lot of things in life, there are trade-offs. I am using the 17 pound cap and I have never had a problem.
Old May 7, 2007 | 07:57 AM
xflagz51's Avatar
xflagz51
I are a college graduate! Lets try that again, "you are making the hoses work harder...."
Old May 7, 2007 | 09:12 AM
Casethecorvetteman's Avatar
Casethecorvetteman
15psi cap will do you perfectly fine Glen, no reason at all to change lower or higher. If you are maintaining the cooling system properly and using a good quality ethyl glycol based coolant (such as Valvoline G-05 at a 50/50 mix) the car wont over heat. Mine never has and its hotter up here in QLD!!!
Old May 7, 2007 | 09:17 AM
Wheelman's Avatar
Wheelman
15psi is standard. I think I am running a 16psi cap.
Old May 7, 2007 | 10:22 AM
rickneworleansla's Avatar
rickneworleansla
Does anyone know what the pressure on a 95 is supposed to be? I replaced mine a few years ago with whatever NAPA had available at the time. I believe it may be a degree or two higher but it's been running fine since.
Old May 7, 2007 | 10:35 AM
Casethecorvetteman
15psi mate
Old May 7, 2007 | 10:59 AM
BigLee's Avatar
BigLee
for those of you operating at cooler than stock temps, and able to reliably maintain them, theres nothing wrong with a 13, or in some cases, even a 7 psi cap...
i had a 7 psi cap on my 86 for a couple of years, with the 160 stat. no issues...
Old May 7, 2007 | 03:02 PM
LT4BUD's Avatar
LT4BUD
Why would you run a 7 PSI cap??????
Old May 7, 2007 | 07:05 PM
sxyvet's Avatar
sxyvet
hi guys,
thanks for your help and advice!
the reason why i asked is i was running a 13 psi cap as i had a head gasket problem with the old standard heads and i wanted to take some preasure out of the system so i used a 13 psi!
but now i want to go back to standard and needed to know what standard cap is!
so i will go get a 15 psi cap and im done!
thanks guys
cheers
glen
Old May 8, 2007 | 04:45 AM
Casethecorvetteman
Yeah youll be fine with that Glen, you wont need or want anything more than 15 pounds
P.S. Mate im not sure if youve done so yet, but you might want to go back and check your "Sythetic Oils" thread
Old May 8, 2007 | 06:11 AM
85 500 horse's Avatar
85 500 horse
You will gain absolutely no performance gains by either decreasing or increasing your cap pressure. The cap only effects the coolant temperature. Go with a 15. That's what should be in there.
Old May 8, 2007 | 07:12 AM
Casethecorvetteman
It has no effect at all on the coolant temperature, what it does effect is the boiling point of the coolant. All coolants ive read the boiling point ratings on are stated using 15psi cap. If you use a lower pressure, the coolant boiling point will be a lower temp. Using a higher pressure will mean it takes a higher temp to boil the coolant.
Old May 8, 2007 | 08:29 AM
jimmers's Avatar
jimmers
The FSM for my 90 says to use a 17psi cap.
Old May 8, 2007 | 08:53 AM
BigLee's Avatar
BigLee
why not???? like i said, if your engine is operating cooler than stock (mine rarely got over 170), then why not take some additional stress off of your radiator tanks, hoses, and heater core, waterpump seals. which can, and sometimes do rupture at 15 psi...
when operating at high rpm, the waterpump can generate differential pressures well above the cap rating in the engine. i have even seen freeze plugs popped out of engines before, while racing...
To " what preasure radiator cap please?"
Old May 8, 2007 | 09:08 AM
Casethecorvetteman
Yes mate, with you BigLee, if its enough pressure and youre not boiling the coolant then there is no reason not to go lower i guess
Old May 8, 2007 | 10:22 AM
kalister1's Avatar
kalister1
Has anyone used the cap with the temp gage built in?
Old May 8, 2007 | 10:35 AM
Casethecorvetteman
Funny you ask, a friend of mine put one on his 85. I have seen it installed, but never seen it in action.
