Tough power steering pump
It separated at the outside fitting (high pressure) to the steering rack. That blew fluid over that side of the engine, drivers wheel and brake. I drove the car home as it was (about 50 miles of Interstate) and assumed that I would probably have to replace the pump and hose. I had decided to drive toward home and call for a tow if the pump made noise. No noise so I kept driving. Got home, had a new hose within two hours, did the replacement and got back to the track for my last session Saturday. The pump did fine for that trip and 20 minute session and all next day (four sessions and another 100 miles roundtrip).
As I told someone at the track whose BMW was being carried back to San Jose because of a power steering hose failure, there are advantages to driving a Chevy.
By the way, had to use brake cleaner on the driver's side disk and pads for obvious reasons -- let's say something more that a "pull to the right when braking"-- but they were fine afterward (straight and true stops on course at speed).
Would you have expected the pump to burn up?
Steve
Carl Johansson
Steve
But, my big surprise was that I could drive over 50 miles with no fluid in the reservoir or pump without causing damage. At least the reservoir was completely dry and the hose was disconnected at the steering rack.
