tranny Question
Old May 7, 2007 | 11:47 PM
Phatoscar's Avatar
Phatoscar
Default tranny Question
I have a late 86 corvette with auto tranny. I just rebuilt the motor and then 3 thousand mile late the tranny went out! Third slips very bad and overdrive is complitely gone! I did beef up the car a little bit... The car has 212XXX miles on it! Was it an extra ponnies that made the tranny go or do you guy/gals think it was do to wear??? How much horsepower can the stock tranny handle?
Old May 7, 2007 | 11:52 PM
Pete K's Avatar
Pete K
212,000 miles on an origional trans is exceptional. They usually die of old age exactly as you describe. 3-4 clutch pack is normally the first to fail. There are many proven recipes for rebuilding and upgrading a 700r4. Consult your rebuilder and seek his advise. You can easily and somewhat inexpensively build them to hold 450 hp and 450 ft lbs.
Old May 8, 2007 | 12:04 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Listen to this guy, he knows his chit, ask him real nice and see if he'll build you a trans.
Old May 8, 2007 | 12:57 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
It's doubtful the extra power fried your transmission.
But it gave you an awesome 212,000 miles of use.
You can only hope your next transmission lasts even close to that long.
Old May 9, 2007 | 02:34 PM
Phatoscar's Avatar
Phatoscar
Hey thanks alot for the input! I got it fixed already! It was rebuilt with set of heavy dutie clutches... I like it!
Old May 9, 2007 | 09:48 PM
Z06_BluByU's Avatar
Z06_BluByU
Hell i've done mine three times in 178k miles! Hopefully this last super build (that peteK helped steer me in the right direction) will last 212k miles!!
Old May 9, 2007 | 10:05 PM
Aardwolf's Avatar
Aardwolf
I had a similar problem and it was a bad TV cable, plus high heat making varnish in the valve body. Drop the pan and see what is in there. I found it free of metal so dropped the valve body and found debris in it. All it cost was a TV cable (it would not adjust) and some ATF. I did put a shift kit while I was there.
Old May 9, 2007 | 10:38 PM
Repzard's Avatar
Repzard
Are the Raptor 700R4 good??
They claim they are bullet proof to handle high HP
Old May 10, 2007 | 08:13 AM
Z06_BluByU's Avatar
Z06_BluByU
when i looked into those my research let me to believe people have had mixed results..
Old May 10, 2007 | 08:20 AM
anesthes's Avatar
anesthes
He's the man. Gave me some damn good advice when I did my dana36 re-gear.
-- Joe
Old May 10, 2007 | 09:09 AM
Batyrkhan's Avatar
Batyrkhan
Hey,
I have te same problem on my 1995 LT1.
Pete K, was very nice and gave soem info about trans.
Tell me what kind of heavy duty kit you used? And where did you get it?
Batyrkhan
Old May 16, 2007 | 05:12 PM
Phatoscar's Avatar
Phatoscar
I dont know what type to be honest! They guy is a good friend of my dads so he took care of the whole thing! Droped it of one day picked it up the next! Amazing work!
Old May 16, 2007 | 08:07 PM
Z06_BluByU's Avatar
Z06_BluByU
I think the ones I used were made my Alto and were called Red Eagle something or other..
Old May 17, 2007 | 02:40 AM
sami85L98's Avatar
sami85L98
Pete k built mine and i swear drove like there's no tomorrow. 17k miles still counting. thanks pete k
To tranny Question
