My L98 needs a hotter plug/suggestions
Old Oct 20, 2001 | 11:50 AM
AS84's Avatar
AS84
Default My L98 needs a hotter plug/suggestions
I have stock replacement delcos currently.
Old Oct 20, 2001 | 11:58 AM
Red85's Avatar
Red85
Default Re: My L98 needs a hotter plug/suggestions (AS84)
What's the plug look like immediately after a hard pass? Are they fouling?
Old Oct 20, 2001 | 12:00 PM
AS84's Avatar
AS84
Default Re: My L98 needs a hotter plug/suggestions (Red85)
The electrode looks grayish black but down around the threads its a thick black. Fuel pressure is set at 48 psi.
Old Oct 20, 2001 | 12:15 PM
Red85's Avatar
Red85
Are they wet, and if so, is there a gasoline smell....or is it just a dry carbon buildup? Reason I'm asking is because often times a breakdown in plug wires/cap & rotor/ or ignition module will mimic the need for a "hotter" plug...which really does nothing more than transmit heat to the cylinder head at a slower rate. In any case and to answer your question, increasing the numeric value of your plug increases the heat range, i.e. R43TS to a R44TS.
Old Oct 20, 2001 | 12:16 PM
nickd's Avatar
nickd
try turning your fuel pressure down a bit.
just my .02
Old Oct 20, 2001 | 12:31 PM
AS84's Avatar
AS84
A few on the passenger side have been wet, but other than that its just dry carbon build up. I've been thinking of upgrading my ingnition system but haven't checked it all out yet.
Old Oct 20, 2001 | 12:50 PM
Red85's Avatar
Red85
AS,
Adjusting the heat range up or down should be the last thing after you've verified the PCV, EGR, secondary ignition, and fuel pressure systems are o.k. I realize this sounds silly, but are those heads original to the car....or aftermarket? GM and lots of modifiers use heads that require 3/4" reach plugs and a stock 1/2" plug will foul quickly....but CHECK THE DEPTH before switching!
Old Oct 20, 2001 | 02:46 PM
AS84's Avatar
AS84
It has stock heads. It has a new EGR valve and solenoid and the pvc seems to be ok but it isn't new. Ever since I did the mods it has a long crank on a cold start. i just figured it was due to the stock ignition.
To My L98 needs a hotter plug/suggestions
