Myth Busted
Old Mar 10, 2008 | 12:50 PM
dan_t's Avatar
dan_t
how did you get on with this?
Old Mar 10, 2008 | 03:30 PM
85blkrose's Avatar
85blkrose
the bracket does not have to be from a vette correct? hit the junk yard and find a trashed impala and scab the bracket off that. i dont think they have sticks in those. just remember when at wot the tv cable should be maxed out and use the pedal the do wot not your hand on the linkage.
Old Mar 10, 2008 | 04:59 PM
MR NICE's Avatar
MR NICE
Had to fab a bracket so i could use the stock length cables.
Old Mar 10, 2008 | 05:11 PM
pr0zac's Avatar
pr0zac
i wish i saw this earlier.. i did this swap on a 1991 camaro with a 700r4 and it wasn't too bad.. the tv cable should adjust fine.. i had no issue at all with that.
Old Mar 10, 2008 | 05:23 PM
steven mack's Avatar
steven mack
If you are not sure of the proper adjustment on your trans cable ,some good insurance in not burning up your trans is a constant pressure valve body by TCI.Summit has them in there catalogue for$230 not bad for the piece of mind.
Old Mar 10, 2008 | 07:11 PM
FD2BLK's Avatar
FD2BLK
I did an LT1 swap into my 84 so you should be able to use the same setup as me. You need a 94-up SS Impala Throttle Cable, a 93 style throttle adapter from S&P or a 92/93 LT1 TB, 93 Camaro Throttle Bracket and a lock up kit for your converter. Give them a call as it has been a few years
http://www.hotrodlane.cc/08%20catalo...talogMAIN.html
Old Mar 10, 2008 | 07:32 PM
KENS80V's Avatar
KENS80V
Here is how I did it. My throttle body is the 94/96 style. I made my own linkage bracket as these (94/96) throttle bodies did not have provisions for the TV cable. Hotrod Lane also sells them as stated above.
The TV cable and bracket is from a 93 Camaro. The throttle cable is from a 95 Camaro. Because of the geometry involved...it's important to use the specific 93 TV cable. You can also see in the pictures the modification needed to the stud for the fuel rail cover as the TV cable runs right in the path of the cover stud.
Old Mar 11, 2008 | 09:38 AM
kalister1's Avatar
kalister1
Originally Posted by RacerX70CC
Guys today have it so much easier... hell, back when I started building/racing cars, oftentimes you HAD to "manufacture" or modify your parts as you couldn't jump on the Net, call up Scummit, etc. and have your solution inhand. Those of us who could, did... and that's what separated the runners from the posers.
OK, I am going to apologize in advance for this. Both to Mr. NICE (OP) and RacerX70CC.
But I just have to ask.
Did you have to walk up hill, both ways to school? In the SNOW? With no SHOES?
Old Mar 11, 2008 | 09:44 AM
RacerX70CC's Avatar
RacerX70CC
How'd you guess?
Old Mar 11, 2008 | 03:10 PM
MR NICE's Avatar
MR NICE
The no shoes was before my dad got a job.
