1/4 Mile Time Slip - Reasonable?
Old May 8, 2007 | 06:08 PM
Atok's Avatar
Atok
Default 1/4 Mile Time Slip - Reasonable?
How's this look?
60ft - 2.223s
1/8 - 8.857s @ 84.8mph
1/4 - 13.513 @ 106.4mph
I shifted at 5300rpm, clutch on each shift, full tank of last year gas, spun a bit too much at the start I think. Do you figure I'll get it down to 13.1 if I squeeze it hard?
Winter is over... it's good to be back in the saddle.
Old May 8, 2007 | 06:12 PM
jeffyc's Avatar
jeffyc
hi Atok, nice to see some one from my part of the world here
and where did you 1/4 mile it?
Old May 8, 2007 | 06:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you can get that short time down into the low 1.9s your ET should drop about .5sec...
Try launching with about 1/4-1/3 tank of fuel and leave the jack home.
Once you have the launch perfected, try varying the shift points for best ET.
What kind of rear tire, what inflation, what kind of burn-out, what staging (shallow or deep)????
Old May 8, 2007 | 07:27 PM
TM-Z06's Avatar
TM-Z06
1/2 tank / lower tire pressure- shift at 5500 and you'll be in the low 13's (and possibly 12's)
Old May 8, 2007 | 08:23 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I don't know. I have no idea what the hell you're driving. But anything you can shave off your short time will help you X2 on the other end.
Old May 8, 2007 | 08:27 PM
Carpenter's Avatar
Carpenter
The issue is your 60'. Try lowering your tire pressure in hopes it'll hook.
Old May 8, 2007 | 08:38 PM
1stvette94's Avatar
1stvette94
I went 13.1@109 in my stock 94.
power shift 5500
20 psi
1/2 tank
3522 lbs race weight
44* temp
Old May 8, 2007 | 08:45 PM
Carpenter's Avatar
Carpenter
power shift 5500
20 psi
1/2 tank
44* temp
You mean you ran in open loop? Or was it just a cool day? What was your 60?
Old May 8, 2007 | 08:52 PM
1stvette94's Avatar
1stvette94
outside air temp
1.98
coolant temp 180*
oil temp 200*
Old May 8, 2007 | 09:09 PM
Carpenter's Avatar
Carpenter
DR's? Or street?
(must be a good track)
Old May 8, 2007 | 09:30 PM
1stvette94's Avatar
1stvette94
DR's? Or street?
street, but now i just use dr's for bracket racing.
haven't gone any faster, but i don't have to worry about spinning.
you can get the most out of your car with street tires and stock power, but it's a fine line between hooking and spinning.
Old May 8, 2007 | 09:43 PM
1stvette94's Avatar
1stvette94
Originally Posted by Atok
How's this look?
60ft - 2.223s
you can get there.
PRACTICE, PRACTICE, PRACTICE and hope for good air
you'll also have to bring your rpm's up to at least 1500 and let the clutch out as fast as you can without spinning and flooring it at the same time. you don't want to slip the clutch, that will kill your et. experiment with launch rpm the higher the better. it's a fine line, but once you do it all the way home.
Mojo went 13.0 with his 95 when it was stock
Old May 8, 2007 | 11:06 PM
856SPEED's Avatar
856SPEED
power shift 5500
20 psi
1/2 tank
44* temp
Congrats....that is BY FAR the fastest STOCK LT1 car.....109.......You are running in modified LS1 territory....not bad for 300 horses!!!
Old May 9, 2007 | 12:10 AM
crossfire7's Avatar
crossfire7
power shift 5500
20 psi
1/2 tank
44* temp
So this is from a bone stock 94 LT1 6-speed?
With your weight and mph, you would be putting out 375-400 HP at the crank....sorry but my balogna detector is going off.
Old May 9, 2007 | 12:12 AM
crossfire7's Avatar
crossfire7
How's this look?
60ft - 2.223s
As others have stated, get that 60' down and you will be there.
Old May 9, 2007 | 06:13 AM
93 ragtop's Avatar
93 ragtop
My bone stock vert, with a 3.54 gear and a chip trapped at 105.xx. Consider that gears do not help trap speed, verts are heavier, and mine is a automatic, I know he could trap in the 106 range.
FWIW, under ideal conditions, traction, gearing, etc, 106mph will put you well into the 12's. But, when you start hooking hard, parts do break on these cars, at least that has been my experience.
on your numbers.
Old May 9, 2007 | 03:44 PM
1stvette94's Avatar
1stvette94
OK, you caught me, I lied. I went 108.91 mph, sorry.
Come out to the corvette challenge this weekend, oh I see you're in texas, easy to talk from so far away. Don't lie, never have, never will, no reason to. When I braket race I usually dial 13.20-13.30, and my trap speeds are between 106-107. It was the perferct run on a perfect night. Don't know what the da was, wouldn't doubt it if it was negative. Englishtown is one of the fastest tracks in the country because of how close to sea level and the great air (cold, dense, dry). There are bone stock auto lt1's running 13.5 with much warmer weather then when I ran my best. All the modified ls1's with head, cam, exhaust are running 11's.
To 1/4 Mile Time Slip - Reasonable?
Old May 9, 2007 | 06:35 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
My 95 ran 8.6 @ 84 in the 1/8 my first time out. After that the clutch and tires were slipping to bad to do any better.
Old May 9, 2007 | 09:06 PM
sweetsoul's Avatar
sweetsoul
Default 1/8 th
my stock 91 did 8.84 in the 1/8 before mods.......auto , 2.59 gear cant wait to get back since my top end work intake ,runners ,plenum , 1.6 rr's
Old May 9, 2007 | 10:05 PM
92lt1vet's Avatar
92lt1vet
Default 1stvett94 is right
englishtown is a great track i went 13.30 with my bone stock 2.59 gear set automatic lt1 coupe with a 2.08 60ft at a lil over 105mph which i thought was pretty gd so he def could have gone that fast just my imput
