1988 Corvette
Old May 8, 2007 | 09:27 PM
Nascar's Avatar
Nascar
Default 1988 Corvette
On my 1988 Vette the small fan out in front what temperature will it get to before it kicks on? not sure if that fan works.
Thanks Dan
Old May 8, 2007 | 09:32 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
about 238*
Old May 8, 2007 | 09:38 PM
scorp508's Avatar
scorp508
387.59* Kelvin
Old May 8, 2007 | 09:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Just ground the connector to the Grn wire going to the Aux Fan switch (below #1 & #3 spark plugs) and the fan should come on if the ign is on.
Or you could ground the Grn wire at the Booster Fan relay, mounted on the upper LH side of the radiator shroud.
Old May 8, 2007 | 10:00 PM
vader86's Avatar
vader86
Originally Posted by AGENT 86
about 238*
Thats what it is for 86, but I believe for 88 the temps were dropped.
Certainly not below the main fan setting though.
Old May 8, 2007 | 10:03 PM
Aardwolf's Avatar
Aardwolf
You could jumper 12 volt to it as well?
To 1988 Corvette
