ujoint help
Old May 9, 2007 | 02:32 PM
dwestsr's Avatar
dwestsr
Default ujoint help
I have searched the tips section and the search function but I can't find the how to tip on replacing the rear ujoints in my 86 coupe. Can anyone share their knowlege about how to do this. I have the service manual, but I was wondering in particular if it was necessary to drop the rear spring in order to get the half shaft out. I seem to remember a tech tip on this but the one in the tips section is blank. Any help is appreciated.
Old May 9, 2007 | 02:55 PM
evmlarry's Avatar
evmlarry
http://temp.corvetteforum.net/c4/vad...orpujoint.html
Old May 9, 2007 | 05:49 PM
carriker's Avatar
carriker
Whoever made that writeup should have a small country named after them. It helped so much.
Old May 9, 2007 | 07:55 PM
dwestsr's Avatar
dwestsr
Many thanks, that was exactly what I was looking for.
Old May 9, 2007 | 07:58 PM
N.C. Kid's Avatar
N.C. Kid
I think that was scorps site. Not postive on that though. Very imformative.
Old May 12, 2007 | 02:13 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Yes, it was scorp508 who originally posted that write-up. I used it when I replaced my half-shaft u-joints. After I buffed clean the straps and the bolts like he did, I sprayed the bolt heads and straps with high temp clear engine enamel. The clear protects the metal and sheds the dirt and debris so that they still look new, many thousands of mile later.
Old May 12, 2007 | 08:32 AM
scorp508's Avatar
scorp508
Somewhere warm please.
Old May 12, 2007 | 09:42 AM
carriker's Avatar
carriker
How about Somalia? Could be called Scorpmalia...... It's warm too. I see nothing but potential.
Old May 12, 2007 | 12:43 PM
scorp508's Avatar
scorp508
Sure, but only if you become mayor of Mogadishu.
Old May 13, 2007 | 09:58 PM
carriker's Avatar
carriker
Mayors get complimentary C6's right? If so I'm in.
Old May 14, 2007 | 12:34 AM
blkzr1's Avatar
blkzr1
Default u-joint help
i would also replace the coated washer that is between the wheel bearing and the splined output shaft when you have it all apart. i got them from the chevy dealer for about $5 each. the part number is 14076924. my 86 developed a squeek at the right rear and after much heartburn, it was this washer.
To ujoint help
