Oil pressure problem
Old Oct 20, 2001 | 06:10 PM
1BadC4's Avatar
1BadC4
Default Oil pressure problem
I just got my car back from the shop where they were rewiring the wires from the batter to the distributor which had fried. Anyway, I'm driving around about an hour later and gun it to see if its still pinging, which it is, so I back off. My guage switches over from oil temp to oil pressure and kindly alerts me to the fact that it has dropped to 7 then 4 then 0. I quickly kill the engine. Everything appears normal so I start it back up. Sounds fine. On the way home, whenever I brake hard, accelerate hard, or take a turn at more than 10 mph, the oil pressure reading drops to 0 then bounces back up. I am obviously afraid to drive the car now. Do you think this could just be a screwed up reading caused by the wiring work or is it really the engine?
Old Oct 20, 2001 | 06:14 PM
bogus's Avatar
bogus
Default Re: Oil pressure problem (1BadC4)
thats a tricky one...
if you can, check the sender. make sure it is ok.
also, check the oil level.
if those things don't help, it could be the pump... sad to say...
Old Oct 20, 2001 | 06:44 PM
LT401Vette's Avatar
LT401Vette
Probably is the wiring. The oil pressure sending unit is right next to the distributor.
Check for loose connections near the sending unit. Also make sure it is full of oil :)
Old Oct 20, 2001 | 07:20 PM
Plasticman's Avatar
Plasticman
The fact that it goes to zero when you brake or turn, etc. could mean that it is a wiring problem, but it could also mean that the oil is washing away from the oil pick-up. I assume you have checked the oil level? The only other reason could be a pick-up that has come off of the pump (if you don't find any problems in the wiring, it is time to drop the pan!).
Either way, I would not be running it without oil pressure.
Good luck,
Plasticman
Old Oct 20, 2001 | 08:31 PM
vette punk's Avatar
vette punk
I would suggest you back up and cover the basics first. Engine oil in good condition and at the proper level? Using a quality oil filter? Is the engine making odd sounds? Have you confirmed the correct oil pressure with a known good MECHANICAL gauge? Have you driven the car with the mechanical gauge attached? Just my 2 cents.
Jim B. :D
To Oil pressure problem
