Lift NOT lower a C4
Old May 13, 2007 | 04:28 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Larger diameter tires would be the best solution.
Raise the car too much and you'll mess up the suspension goemetry.
The rear is easy, just use shorter bolts.
For the front, I'd shim the stock mounts.
Wait...
If the front is scraping, try lowering the back. Take the rack out of it, if you follow me. real easy to try, and put back if is doesn't work.
Old May 13, 2007 | 04:38 PM
nitecruizer's Avatar
nitecruizer
N.C. Kid sounds like he has a problem with "rednecks", maybe one of the "raised" trucks hurt his pride or something, or stole his wife/girlfriend. I am sure they think the world of their vehicle just like you love your vette. Different strokes for different folks. I guess you could call me a "redneck" vette owner as I have a couple of vettes and yes a "raised" up pickup 4 wheel drive to work on the farm.
Redneck Cruizer
Old May 13, 2007 | 04:58 PM
N.C. Kid's Avatar
N.C. Kid
Redneck Cruizer
Um actually your wrong. My father was brought up on a farm. I go to a "reckneck/hillbilly" school and I love it there. Alot of my friends are country, my ex gf was semi-country/prep. I have no problem. I have gone off roading in my dads jeep. Its not jacked up but its still a blast. I have gone in those high up trucks and it scared the **** outta me. I wasnt meaning it in a disrespectful term and I am sorry if you saw it that way. I was just merely expressing the way i was viewing raising a vette like raising a pickup truck/jeep. Its his car and there trucks/jeeps. Have at it. Either way its not affecting me unless I ride in it with them and it sure is fun looking down at the cars when your cruising.
Old May 13, 2007 | 06:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
Brian Cunningham had some good suggestions....Or just mod the dip in the driveway and leave the car alone
Old May 13, 2007 | 06:47 PM
JoBy's Avatar
JoBy
A pair of Hi Jackers Air Shocks at the front would do the trick without modifuing anything else. You would also be able to adjust ride hight at the front very easy when they are installed.
I don't know if there are any 'bolt on' Hi Jackers but it should be easy to find a pair to modify.
Old May 13, 2007 | 07:48 PM
ubnpast's Avatar
ubnpast
simple solution: hydros or airbags
Old May 13, 2007 | 08:09 PM
Repzard's Avatar
Repzard
Originally Posted by bogus
I wonder if your car already has a lowering kit... it might be worth checking that.
also, new springs will bring it up.
the best bet would be coil over shocks, that you can control the ride height.
With Bogus
Coil Overs would do the trick.
Old May 13, 2007 | 08:32 PM
aboatguy's Avatar
aboatguy
I don't like the C4's stock ride height in fact I hated how high my vert was stock and slammed it. However, it your car and you can raise your rear by tightening the bolts and/or placing more shims above the rear spring (between the diff and spring)
The front can be raised with new springs (especially if yours is sagging/delaminating) or by placing some spacers above the spring (between the spring mount and the crossmember kind of like on the rear) You may need to replace the mounting bolts on the front with longer ones if you use the spacer idea.
If you have the money coil overs, hydraulics or air bags are options too.
Good luck!
Mike
Old May 13, 2007 | 09:12 PM
DanZ51's Avatar
DanZ51
Being you already have some alterations up front, how about adding some type of caster under the front spoiler. Hopefully it would be non-visable and could "slide" you over the bumps.
Old May 14, 2007 | 06:57 AM
sxyvet's Avatar
sxyvet
hi guys,
my 1991 zo7 vette here in Australia is lowered all round with coil overs as you would of seen and it is low!
i have designed/tested a product that i have called a " roller lift " tm product that attaches to the front lower part of the car each side that works just beatiful!
it is similar to a solid castor wheel and attaches by a bolt/nut with ease!!
this product is fitted to my car and has been for the last 1.5 years!!
and i am thinking of going into production with this kit and marketing them to the corvette public as such!
it is great that works awsome and saves the lower front part of your car from getting scratched/damaged and i would be lost with out due to some such sh*it drive ways around the place!!!
it lifts the car up just enough as im driving slowly forward over the nausty drive ways/bumps e.ct. and clears the bad angle to the front is clear and then away i go!!
any way cheers
glen
Australia
Old May 14, 2007 | 07:49 AM
anesthes's Avatar
anesthes
Originally Posted by 383_BluByU
my point was raising the car will hurt its performance and handling characteristics.. I know options 2 and 3 were absurd - I was trying to make a point.. maybe too harsh..
In all seriousness make sure the car hasn;t been lowered already.. stock ride height should work just about anyplace in the USA.. I traverse some tall speeds bumps daily.
You aint been to new england, have you? Some 4x4s scrape here.
-- Joe
Old May 14, 2007 | 09:01 AM
ODIVETTE's Avatar
ODIVETTE
Just back into your driveway
Old May 14, 2007 | 09:53 AM
  #33
edar's Avatar
edar
Default QA1Shock SOlution
QA1 shocks can be adjusted for that 1/2 inch height you are looking for. I have a similar problem with my C4. I have been considering QA1's in the front and regular Bilsteins in the rear. They run almost $200 each however.
Old May 14, 2007 | 10:05 AM
  #34
Powersmokin's Avatar
Powersmokin
get the suspension off of a vert.I was told they sit one inch higher then the coupe.
Old May 14, 2007 | 10:52 AM
  #35
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Maybe your front spring is already shot.
Take a profile shot of your vette on level ground w/ no fat bitches in it and let us judge.
Old May 14, 2007 | 11:08 AM
  #36
-=Jeff=-'s Avatar
-=Jeff=-
this one tall enough??
Sorry after reading the first reply about 33" tires, I thought of this.
Not intended to offend the OP about his quest
Old May 14, 2007 | 03:33 PM
  #37
Black94Coupe's Avatar
Black94Coupe
HAHA!! Thats what IM talkin about!!!
Matt
To Lift NOT lower a C4
Old May 14, 2007 | 04:42 PM
  #38
sonomacrew01's Avatar
sonomacrew01
If the car is primarily scraping the front, remove the black trim below the front bumper cover. If it is still scraping (frame rails), buy a "fat daddy" frame saver
http://www.customcorvetteaccessories...fattdaddy.html
But lifting a car on stock suspension messes with the suspension geometry, drivetrain (u-joints), bump-steer and premature ball joint failure.
Old May 14, 2007 | 06:44 PM
  #39
CentralCoaster
Lifting only the rear will make the front scrape worse.
Old May 14, 2007 | 11:05 PM
  #40
quiksilver458's Avatar
quiksilver458
My advice would be to have the driveway poured to better suit the angle needed. This is probably cheaper than adjusting everything on the vehicle. Plus it will make the property more convenient to access.
