87 AC main line removal
Old May 14, 2007 | 12:48 PM
87vette's Avatar
87vette
Default 87 AC main line removal
I was wondering what I need to be aware of before I disconnect the main line from the evaporator to the AC compressor? My hose split and its getting the underside of the hood greasy and wet. I ordered a replacement from Vette2Vette. Am I able to just unbolt it and throw on the new one without junk getting sprayed everywhere? And am I going to be able to charge it with the R134A easily once I do so?
Old May 14, 2007 | 01:25 PM
Wheelman's Avatar
Wheelman
If there is anything left in the lines, you should have a shop recover it before you pull it apart, and replace the accumulater / drier since you had the system open. Make sure to pull a vacuum on the system for at least a half hour before you charge it again! Were you able to get a NEW line from Vette to Vette? or was it just a used part...
Old May 14, 2007 | 02:45 PM
87vette's Avatar
87vette
It was used. What do u mean by pull a vacuum on the system before I charge it. What does that do? As for the accumulator.. are you referring to the evaporator cannister?
Old May 14, 2007 | 04:12 PM
Wheelman's Avatar
Wheelman
Pulling a vacuum sucks all the air/moisture out of a system. The accumulator / reciever drier is the metal round cylinder at the front of your engine bay.
Old May 14, 2007 | 05:48 PM
87vette's Avatar
87vette
So how would you vacuum something like this? Is there special tool that is needed? I would prefer not to take it to the shop since I know AC work is expensive. I'm moving to GA next month and do not want to spend much so that will be out of the question for now. Just trying to fix all the little things on it before the road trip with the Vette.
Old May 14, 2007 | 07:20 PM
c4cruiser's Avatar
c4cruiser
Take the car to a good shop that specializes in A/C work. If you have no experience in doing this sort of thing, it's easy to really screw things up to the point where you could ruin the compressor. That's big money for the old style radial compressors!
Are you going to re-install R-12 or convert to R-134a? Is the condensor free of debris and dirt? With the system opened, a new accumulator would be in order especialy if the hose you are getting is used.
Old May 14, 2007 | 07:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Why would you buy a used hose? Vette2vette doesn't sell new parts.
I took mine to a local AC shop to replace the hose and braze the hose ends back on, since the GM replacement was too short.
Old May 14, 2007 | 07:42 PM
87vette's Avatar
87vette
It was already converted to R-134a several years back. Where could I get a new accumulator from at a decent cost? I guess purchasing a used one is out of the question then right?
Old May 14, 2007 | 07:44 PM
87vette's Avatar
87vette
Yeah? Vette2Vette actually sells some new parts. How much did it cost you to replace your hoses? Maybe I should send the hose back once I get it.
Old May 14, 2007 | 07:47 PM
CentralCoaster
I bought from Chris May at superior chevy with forum discount, including new compressor, accumulator, both hoses.
Parts were slightly cheaper than Rockauto.com and way cheaper than everywhere else.
The hose that didn't fit I sent back, the local shop charged me the same price as the new one to redo it, about $80 I think.
Old May 14, 2007 | 08:16 PM
87vette's Avatar
87vette
How much did all parts cost you without the compressor from Superior? Looks like this is gonna get expensive. Might just have to tape up the hose where the slit is and hold it off till another time. Gonna be a hot trip down.
Old May 14, 2007 | 09:05 PM
CentralCoaster
Accumulator $38
Compressor $268
Cond Hose $79 (but it didn' t fit)
Orifice Tube $2
Shipping $30.25 (Compressor was most of weight)
Compare with rockauto and oehq.com
Also local hose shop charged me $95 to redo compressor hose assembly, $49 for condensor hose, $11 tax.
Crusing through the Mojave desert in my ancient sportscar with 40F air blowing on me... priceless.
Old May 14, 2007 | 09:18 PM
87vette's Avatar
87vette
Accumulator $38
Compressor $268
Orifice Tube $2
Thanks. Maybe it won't be so bad. Just ordered a new set of Sumitomo HTR Z tires for the trip down in replace of my 7 yr old Bridgestone Potenzas. Might just buy the parts for now and hold off on the install till I get down there. If I get hot.. then I guess I'll take the top down
Old May 14, 2007 | 09:23 PM
CentralCoaster
That's what I thought last summer. And then it ended up being the worst heat wave in recorded history. Serious.
Old May 14, 2007 | 09:44 PM
87vette's Avatar
87vette
That wouldn't be a good thing. I've got 3 vehicles and the 97 Blazer is going on a trailer due to the fact that it needs work. The Xterra will be driven by my fiancee with my 2 kids. So I have no choice but to drive the vette. Moving sucks, thats for sure. Can't wait till its over with.
To 87 AC main line removal
