As some of you guys may know I am building a 383 LT4. It is going to be complete internal balance. I know I cant run the dual mass fly wheel the way it is or it will vibrate. My question is can you remove the weights from the flywheel and make it work?
I know about using a neutral balance Camaro flywheel. What are some good combos going this route? Since there is not a kit for this.
YES YES YES YES YES YES YES you can Zero balance a dual mass... I'm using such a flywheel.
flip over a dual mass can will see the large weight that was added. Just remove that and check the balance. Should be VERY VERY VERY CLOSE to Zero / Neutral. Then add weight were need to the outer edge holes and you have a perfectly neutraly balance DM flywheel...
Ok now that I know I can use the DM flywheel, mine has about 50,000 miles on it, and looks pretty glazed up along with the pressure plate. I have read that you can not resurface these. When you guys make them neutral are you using new or your old flywheel?
Also, the 2 halves of my flywheel rotate separate of each other a few degrees and then stops. Is this normal?
I had mine resurfaced at the same time as the milling/ballancing.
All info I searched out told me that it COULD NOT be done without some 'special' equiptment (don't ask me....I'm not a machinist). I had it done anyways. (My machinist was worried about the movement between the two plates and claimed 'he'd try, no guarantees'...reasonable warning I surmised)
It all worked out ok though.
Mine had 60 k. Even though I couldn't manually 'move' it more than....say.....one degree.....the machine torque/stone friction would have concievably 'moved' it a few more degrees? By my thinking....so long as the entire plates remained TRUE to his table (and that his machine oil wouldn't degrade the rubber shock between the plates)....the grind would remain 'true' to the crank mounting.
My other choice aside from buying a new DM flywheel (which would STILL need machining/ballancing) was to go with a SM cast or aluminum. I considered that...but my ZF had previousely been SO noisy (twice, guys pulled me over to check out my blower! ).............(I am NA, btw).... Anyways, I lucked out. The machining worked great.....plus for some strange reason my ZF quieted down after I re-installed it. (It MUST have been mis-aligned or something? Perhaps bad throw-out on the old clutch? Dunno, really.)
Anyways, that's been my experience.
There is no "rubber shock plate" between the two masses.
There is however a thin metal flange that can be bent.
I took mine apart to see what was in there once and for all.
There is only light oil as a film in there, just to keep the spring lubed.
Before I found this forum in 2000(I lurked for a few months ), I had a local shop do the clutch. Unbenounced to me,they turned the FW.
The cutting fluid used when resurfacing could get in between the 2 masses.
They had wrapped rags between the 2 masses so as to prevent the fluid from getting in there.
The car worked fine.
I bought a new one. Less chance of issues later on....
I just called a local clutch company and I told them my situation. The guy told me he could resurface the flywheel but did not think he could balance it, even with the weight removed to make it neutral. He said since the 2 halfs move he didnt think it would work.....Anyone
Contact George Coleman and tell him Robert from Northern Virginia told you to call about balancing a DM flywheel. He did one for me about 2 months ago.
Coleman Automotive Machine Shop
White Marsh, VA 23183-0000
(804) 693-3632
As for resurfacing: I would talk to ZF DOC www.zfdoc.com or Tom at Carolina Clutch.
if the movement would effect an balanced DM, it would effect an OEM one. I don't buy that logic.
I looked at my dual mass last night and I believe the counter weight is made to the flywheel. There are a bunch of numbered holes around the outside of the flywheel. One of them has a weight driven into it. I think I am just going to go with the Camaro flywheel.
Had my DM zero balanced by a local machine shop (383 build) - he removed the cast weight (machining operation), left the balance weights in the flywheel and zero balanced the entire assembly to within .4 grams.....car runs very smoothly. He did NOT resurface the flywheel, however.
