Tps/iac 86 L98
Old May 14, 2007 | 09:07 PM
WildWilly55's Avatar
WildWilly55
Default Tps/iac 86 L98
hey guys---need your help again. Read a paper on internet from one Lars Grimsrud on www.batee.com Good article on setting up your TPI and IAC. I know it is probably on this site somewhere--but I did search and could not find. He says to set your idle up with in drive against the brake at 450 RPM---seems low to me. After setting my TPI up to .540 VDC---my idle is lower at 500 RPM but it seems to be too low--mind you it is running extremely well. 1986 C4 Coupe L98--High energy Comp Cam--just rebuilt. I have also broken (brittle) vaccuum line between the fuel regulator and the AIR valves up front---do I need the vaccuum line re hooked up to these AIR valves??? I have just blocked it off from the fuel regulator for now. Where do I get these small plastic lines (especially the two into one splitter??) thanx guys---alway apprieciate you guys!!!
WildWilly
Old May 15, 2007 | 12:51 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
450 rpm is the base idle, with the IAC harness disconnected. The engine should idle at whatever the target idle is programmed to in the chip (stock or custom?).
Old May 15, 2007 | 02:09 PM
RRT vette's Avatar
RRT vette
I agree with byebyeL98. Those vac lines can be found at Napa. You can also replace those plastic lines with rubber lines. I would have it fixed, so not to worry about it causing problems with leaks.
When setting my minimal idle (IAC extended and disconnected), my engine sound like it was going to die. Once the IAC is reconnnected, the ECM will use it to get the desired idle in the chip.
Old May 21, 2007 | 09:08 AM
WildWilly55
Hey Guys---thanx for the info---just cruised up to Sauble Beach, Ontario---she ran like a dream---went to NAPA and purchased some small rubber hose --reattached all the vaccuum stuff---set the TPS with my volt meter---running TOP DRAWER!!!
Thanx
Old May 23, 2007 | 04:52 PM
RRT vette's Avatar
RRT vette
To Tps/iac 86 L98
