Could it be a bad injector?
Old May 16, 2007 | 05:44 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Could it be a bad injector?
My Ruby has had a miss.
Thought it was the opti, replaced it, miss is still there.
Thought it may be a bad valve, did a leak down test all was OK
How do you test the injectors?
Old May 16, 2007 | 05:50 PM
bogus's Avatar
bogus
hm... thought you had already done this... you had done SO much...
ok, glad the leak down was ok!!!!
remove the rails, put a little paper cup under each injector, and have someone start the motor (coil disconnected). watch for the spray pattern...
Old May 16, 2007 | 05:59 PM
Rex Ruby's Avatar
Rex Ruby
Is there a way to do a resistance check?
Old May 16, 2007 | 07:37 PM
Demonic85's Avatar
Demonic85
Easier way to test is to stick a screwdriver against each injector while the engine is running. If you can feel clicking then the injector is probably ok.
Old May 16, 2007 | 07:50 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
any plugs fouled?
Old May 16, 2007 | 07:51 PM
Rex Ruby's Avatar
Rex Ruby
Did that with a finger, they all clicked.
Old May 16, 2007 | 08:01 PM
Demonic85's Avatar
Demonic85
Then its possible that it could be a gummed up injector or something of that nature. Have you tried running any fuel injector cleaner?
Old May 16, 2007 | 09:27 PM
NHCorvette's Avatar
NHCorvette
you can check the impedance at each of the injectors, remove the electrical cap off the injector, they should optimally read 16.5 ohms and no more than 1 ohm difference between injectors. Readings below 12.0 are not good.
Old May 16, 2007 | 09:36 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Right, and in case it's not obvious (it wasn't to me): to remove the electrical connector you need to push the metal clip in towards the injector and then pull the connector off.
Gary
Old May 16, 2007 | 11:59 PM
Rex Ruby's Avatar
Rex Ruby
Got 12.6 to 12.3, so are my injectors shot?
To Could it be a bad injector?
