Need Help!!!
Old May 16, 2007 | 09:08 PM
fsufan79's Avatar
fsufan79
Default Need Help window stuck down and rain is coming!!!
i have an 84 and all the sudden tonight my driver side window just wouldnt move. I tried switching the switch with the passenger side one that does work and that didnt do anything. My window was working fine with no problems before this happened. If there is no way of fixing it right away is there any way to put it up permanetly until i find a way to fix it??
Old May 16, 2007 | 10:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
sounds like you have a wire pinched in the door, pull door panel and take a look, test light to see if you have power, motor may have also given out...
Sorry, not sure how to jerry-rig the window up... maybe someone will help
good luck
Old May 16, 2007 | 11:26 PM
fsufan79's Avatar
fsufan79
i found out the window regulator ended up getting stuck because of all the gunk in the motor.. .cleaned it all out and now it works fine!!!
To Need Help!!!
