Ac bolt broken, how to remove?
Old May 17, 2007 | 09:33 AM
dwestsr's Avatar
dwestsr
Default Ac bolt broken, how to remove?
My 86 coupe developed a screeching noise that I traced to a broken bolt on the AC compressor mount that is rubbing on the AC clutch pulley. This is the bolt that has a torx head and also has a flat ground on one side . The problem is that it appears that the bolt broke off in the block , but I can not get it to go past the compressor clutch in order to remove it. Can some one tell me how to get it out easier than removing the whole shebang. I have the helms manual , but I can't find the info that I'm looking for in it. I seem to remember a thread on removing that bolt but I could not find it in Search. Can someone please help?
Old May 17, 2007 | 10:02 AM
Jim D's Avatar
Jim D
I'm afraid you'll have to remove everything. This is not a big job, takes me about 1/2 hr. Just take your time, good luck Jim.
Old May 17, 2007 | 10:03 AM
Carl Johansson's Avatar
Carl Johansson
How many bolts did you break? 1 for each post?
If you can't get to it to drill it for an easy out - I think you have to take it off and work it over on the bench!
Old May 17, 2007 | 10:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Turn the clutch till the notch in pulley lines up with the bolt head.
Or do you already have the broken half out ??
To Ac bolt broken, how to remove?
